#1 2017-05-30 06:06:19
devur
[SOLVED] bit torrent port forward
my problem is, haw do i find the port to forward i my ufw to get bit torrent to download?
Laptop lenovo
Desktop XFCE
Os Devuan beowulf
#2 2017-05-30 07:18:36
smoki
Re: [SOLVED] bit torrent port forward
Launch torrent app you use first and then do:
sudo netstat -ltpnu
It will show you port. Of course if i understand this question right smile
#3 2017-05-30 08:35:52
devur
It looks like i can not start bittorrent or guibittorrent, but when i enable download from the  website that launcher bittorrent  but it comes with an error
Problem connecting to tracker - <urlopen error unknown url type: udp>
i found the port
6881
from a guide, and forward it, but it make no difference.
haw do i launch the gui bit torrent, and do i need a port forward to download devuan?.
Laptop lenovo
Desktop XFCE
Os Devuan beowulf
#4 2017-05-30 11:42:18
devur
yes that is working wink
and bittorrent is removed, it is in repos as well.
Laptop lenovo
Desktop XFCE
Os Devuan beowulf
