#1 2024-02-26 07:06:27
zephyr
Crowz 5.0.1 daedalus new release 2024.02.26
New releases for Crowz 5.0.1 daedalus. Some minor fixes both with Crowz and Calamares installer.
cheers
zephyr
CROWZ
#2 2024-02-26 09:04:33
Re: Crowz 5.0.1 daedalus new release 2024.02.26
Many thanks for the 'heads up'... will grab a copy. smile
#3 2024-02-26 16:08:52
zephyr
Camtaf wrote: Many thanks for the 'heads up'... will grab a copy.
Most welcome, thank you for using Crowz! smile
cheers
zephyr
CROWZ
#4 2025-11-21 13:59:47
Ron
Do you plan on releasing a version based on Excalibur?
#5 2025-11-21 21:55:53
yohno
@Ron. you can build your own from netinstall iso using the script(s) by JustAGuyLinux.( https://codeberg.org/justaguylinux )
He develps the scripts for debian so easily we can apply to Devuan. You'd better to check the codes first. Sometimes you will find it wil be stucking especially at the command line such as sudo systemctl enable avahi-daemon acpid....
Happy linux journey !?
yoshi
#6 2025-11-29 08:10:56
shugg
Crowz is a very cool and stylish distro to use (I like dark themes) but Calamares crashes every time I try to encrypt the system during installation hmm
devuan beginner
#7 2026-01-20 20:12:10
juicyboy
CROWZ ded?
