#1 2024-02-25 16:49:54
bai4Iej2need
[SOLVED] netstat -tulpen: strange output
in the output of netstat -tulpen have these lines amongst others
netstat -tulpen | grep \-
Proto Recv-Q Send-Q Local Address           Foreign Address         State       Benutzer   Inode      PID/Program name
tcp        0      0 0.0.0.0:42397           0.0.0.0:*               LISTEN      0          1874       -
tcp        0      0 0.0.0.0:3142            0.0.0.0:*               LISTEN      108        15793      1656/apt-cacher-ng
tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          15825      -
tcp6       0      0 :::45827                :::*                    LISTEN      0          1877       -
tcp6       0      0 :::3142                 :::*                    LISTEN      108        15794      1656/apt-cacher-ng
tcp6       0      0 :::2049                 :::*                    LISTEN      0          15841      -
udp        0      0 0.0.0.0:57006           0.0.0.0:*                           0          1873       -
udp6       0      0 :::49439                :::*                                0          1875       -
I am wondering, what these lines are with the dash - at the end . Never seen this before.
Something to do with docker , which I recently installed?
broken by design :
#2 2024-02-25 17:26:40
Re: [SOLVED] netstat -tulpen: strange output
A quck test gave me a clue (output truncated for brevity):
$ netstat -tulpen
(Not all processes could be identified, non-owned process info
 will not be shown, you would have to be root to see it all.)
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       User       Inode      PID/Program name
tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          15476      -
tcp        0      0 0.0.0.0:60799           0.0.0.0:*               LISTEN      105        14342      -
And as root:
$ sudo netstat -tulpen
[sudo] password for chris:
tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          15476      2240/exim4
tcp        0      0 0.0.0.0:60799           0.0.0.0:*               LISTEN      105        14342      1343/rpc.statd
So netstat can't find out the PID/Program name if it's not running as root unless the program that opened the socket is running as you.
#3 2024-03-05 22:51:17
bai4Iej2need
Thanks
broken by design :
