#1 2024-02-18 22:46:25
grunchy
disable ModemManager
running daedalus+kde and pstree shows the very first process created by init is ModemManager.
my devuan machine will never need the services of ModemManager and i would like to disable it.
ModemManager is not a 'service' , is not an XDG 'autostart', is not a KDE 'autostart'. it seems to
be baked-in. on my kubuntu box systemd has ModemManager 'masked' so that it never starts.
in devuan how do you stop/disable ModemManager?
#2 2024-02-19 02:39:56
Re: disable ModemManager
Hi, on my daedalus Plasma/kde system, I removed the package ModemManager.
I don't know if it's running (how do you test it to find out?), but I did see Plasma-nm (network manager) depends on some other packages with the modemmanager in the name.
ymmv. All the best
#3 2024-02-19 04:47:15
#4 2024-02-20 18:21:24
grunchy
glenn, yeah i can just purge the package, but was hoping to merely disable it.
there must be something somewhere that instructs init to start this process,
i just cannot find it. i guess purging packages is the usual way in devuan?
swanson, thanks for the clue. sysv-rc-conf is very helpful. the command-line
dump gives a good, condensed view of init-time.
#5 2024-02-20 18:30:11
man service
SERVICE(8)                  System Manager's Manual                 SERVICE(8)
NAME
       service - run a System V init script
SYNOPSIS
       service SCRIPT COMMAND [OPTIONS]
       service --status-all
       service --help | -h | --version
For example
service  network-manager stop
#6 2024-02-24 20:53:24
grunchy
so i found something. not perfect, but better than nothing.
it turns out ModemManager is started by (everyone's favorite) dbus.
the directory /usr/share/dbus-1/system-services contains systemd .service files.
at init-time dbus scans this directory and starts all the listed services.
i did not find documentation about the function of this directory, so it does
appear to just be baked-in to debian. this setup must be documented somewhere
but i did not find out where.
to disable ModemManager just rename the appropriate file so that it get ignored.
so, rename /usr/share/dbus-1/system-services/org.freedesktop.ModemManager1.service
to /usr/share/dbus-1/system-services/org.freedesktop.ModemManager1.service.disabled
the only catch is that if dbus/ModemManager every get updated this change probably
gets stomped-on and needs to be redone. but, since an update is very unlikely until
devuan excalibur rolls around, not too bad.
