#1 2024-02-10 23:09:58
[SOLVED] rockpro64 time broken won't let me install ntp due to 2013 date.
Can anyone tell me how to get this pile of crap to stop being a liar and let me disable gpg altogether? trusted=yes tried allow-unauthenticated tried allow-insecure-repos tried
It keeps saying some nonsense about signature verification failed despite me putting commands like the above to tell it to stop checking.
The reason I need it to stop checking is three fold, cannot go on the internet, cannot install ntp, thinks its 2013, etc...
These  signature checks are a bunch of crap and get in the way too easily.
#2 2024-02-11 09:26:05
Re: [SOLVED] rockpro64 time broken won't let me install ntp due to 2013 date.
If you are using Linux, then surely just set the time yourself.......(see man date).
#3 2024-02-12 01:56:42
tried man date. I actually tried to download openntpd instead of regular ntp and that fixed the problem.
As far as I could see. smile
Appreciate the help though.
#4 2025-10-18 17:28:45
kapqa
hei still wanna buy this
why would you call it crap#?
thought this an awesome one.
#5 2025-10-19 04:54:39
@kapqa the signature checks can be good, but occasionally, they can be a problem.
And sometimes it ain't easy to change them
