#1 2024-02-02 11:14:51
Yomito
[SOLVED] Problematic Debian kernel
Isn't Devuan 6.1.0.15 kernel problematic (a HD corruption bug) as it was Debian kernel with de same number?
#2 2024-02-02 11:52:56
Re: [SOLVED] Problematic Debian kernel
Yes. You should make sure daedalus-security is in  your sources, and upgrade.
#3 2024-02-02 12:18:21
Yes, Devuan kernels are 1:1 Debian kernels. No modification, look at the package names.
#4 2024-02-02 14:50:48
Yomito
Thank you very much for your fast answers.
