#1 2024-01-31 19:43:37
herbie
Thank you
I have to say the Devs have done a great job.  Devuan is GREAT.   Install was flawless and the amount of packages is way lower than any Debian-based release at 1502 and that is with all my games, well only 4 really, but still.   On others it was always over 2000 or high 1900's.  I view that as a big plus as too much software that isn't being used is kinda pointless.
Thanks again Dev's.   Great job.
#2 2024-02-01 08:18:30
jue-gen
Re: Thank you
So far, I have found everything I need at Devuan.
#3 2024-02-01 09:33:18
Re: Thank you
I want to join in the words of gratitude.
It is remarkable that the Devuan team managed to maintain the stability of the progenitor.
If you enable only stable repositories and stop trying to "frankenstem" the distribution will work for years without problems.
I often had questions during upgrades, when developers changed the usual settings in new versions, such as searching for the OS rough.
But thanks to the forum, everything was resolved quite quickly. Thank you.
#4 2024-02-01 09:42:11
Re: Thank you
Yes, the devs have been doing a great job on our behalf, so, I too, would like to add my gratitude for all their hard work.......& also the forum maintainers. smile
#5 2024-02-01 10:51:54
Andre4freedom
Re: Thank you
I want to join the concert, or the chorale:
Thank you Devuan development team, maintainers and
thanks to the forum team
and even thanks to the users that use the forum for friendly and respectful questions and answers.
I can only repeat: use Devuan "stable" and you will get all the best of stability, usefulness and sense (what Linux should be about) smile
Developers will certainly use and develop for the testing and developing branch.
#6 2024-02-01 14:24:37
Re: Thank you
+1 one the above! Thanks Devs!
#7 2024-02-02 09:08:25
entropyagent
Re: Thank you
I do a little gratitude occasionally. (I'm not an addict, I can stop anytime!)
Thanks to the devs/maintainers/forum team.
