#1 2024-01-22 17:26:20
PsySc0rpi0n
Archive is cpio archive. Decompression error.
Hello.
Following this thread, I started a new one because the other one was already quite old
https://dev1galaxy.org/viewtopic.php?id=2952
This is my scenario:
I created a qcow image file and burn Debian Bookworm there. Then I boot it and installed everything I needed there and then I tried to use refractasnapshot to buil an ISO I could take in a pen to my work.
However, at some point I get this error:
"Archive is cpio archive."
And in the logs I could see something relate to intel-microcode and also [ 0 -ne 2 ].
I decided to try to uninstall this package "intel-microcode" and repeat the process. This time there was no decompression error.
So, what is wrong with "intel-microcode"? Is there a workaround?
#2 2024-01-22 22:40:43
nixer
Re: Archive is cpio archive. Decompression error.
To my knowledge, it is a bug and it has not been identified and fixed.  I see it rarely, but I do see it on certain installs - and I can not tell what I do to create it.  On those systems that do have this bug, I always remember to remove the intel-microcode package before making the snapshot.iso file.  Then I install it later.  In other words, only shows in certain installs and I do not know why, yet.  Yes, it is a hassle, but a small inconvenience in my humble opinion.
fsr may chime in and give an update and/or explanation.
#3 2024-01-22 22:53:11
nixer wrote:
... it is a bug and it has not been identified and fixed.
... see it rarely, but I do see it on certain installs - and I can not tell what I do to create it.
For what it is worth, I have been told that this type of 'bug' is referred to as Heisenbug.
ie: a sporadic and non-reproducible bug
Real fun to work on.  8^°
