#1 2024-01-21 11:28:50
Roberto
[SOLVED] fstrim command not found
Hello everyone,
I have installed Devuan Daedalus 5.0.1.
Now I wanted to optimize my SSD and ran the following command manually, both as user and root:
fstrim -v /
Whether as user or root, I get the following error message:
bash: fstrim: command not found
I have run this command hundreds of times on various distros.
Does anyone have an idea what I am doing wrong?
Many thanks in advance.
Greets
Roberto
#2 2024-01-21 12:23:48
Re: [SOLVED] fstrim command not found
How did you try to get root access? A simple su or a su -? Give the
~$ su -
a try.
#3 2024-01-21 12:37:35
Roberto
Hi rolfie,
I had only tried it with a simple su.
Your tip with
su -
solved my problem.
What is the difference between su and su -?
#4 2024-01-21 13:02:53
The path. Thats why you get command not found.
There was a change in Debian some releases ago that moved the su command into a different package and changed the behaviour. I think there is a hint in the Buster/Beowulf release notes.
#5 2024-01-21 13:46:47
Roberto
I come from Arch distributions, so I still have a lot to learn about Debian / Devuan.
Thanks again for your help.
