#1 2024-01-17 19:35:21
deepforest
[SOLVED] Cloudflare WARP, how to install?
Hello
https://pkg.cloudflareclient.com/
Debian
The supported releases are:
    Bookworm (12)
    Bullseye (11)
    Buster (10)
    Stretch (9)
# Add cloudflare gpg key
curl -fsSL https://pkg.cloudflareclient.com/pubkey.gpg | sudo gpg --yes --dearmor --output /usr/share/keyrings/cloudflare-warp-archive-keyring.gpg
# Add this repo to your apt repositories
echo "deb [arch=amd64 signed-by=/usr/share/keyrings/cloudflare-warp-archive-keyring.gpg] https://pkg.cloudflareclient.com/ $(lsb_release -cs) main" | sudo tee /etc/apt/sources.list.d/cloudflare-client.list
# Install
sudo apt-get update && sudo apt-get install cloudflare-warp
but The repository 'https://pkg.cloudflareclient.com daedalus Release' does not have a Release file.
Hit:1 http://deb.devuan.org/merged daedalus InRelease
Hit:2 http://deb.devuan.org/merged daedalus-security InRelease
Hit:3 https://repo.protonvpn.com/debian stable InRelease
Hit:4 http://deb.devuan.org/merged daedalus-updates InRelease
Ign:5 https://pkg.cloudflareclient.com daedalus InRelease
Err:6 https://pkg.cloudflareclient.com daedalus Release
  404  Not Found [IP: 104.19.236.24 443]
E: The repository 'https://pkg.cloudflareclient.com daedalus Release' does not have a Release file.
root@home:/etc/apt#
#2 2024-01-17 20:14:02
Re: [SOLVED] Cloudflare WARP, how to install?
Replace "$(lsb_release -cs)" with bookworm.
#3 2024-01-17 21:13:40
deepforest
tried
i think that not good idea
it take too many space
it might mix bookworm and daedalus
root@home:/etc/apt/sources.list.d# sudo apt-get update && sudo apt-get install cloudflare-warp
Hit:1 https://repo.protonvpn.com/debian stable InRelease
Get:2 http://deb.devuan.org/merged daedalus InRelease [42.4 kB]
Hit:3 https://pkg.cloudflareclient.com bookworm InRelease
Get:4 http://deb.devuan.org/merged daedalus-security InRelease [32.5 kB]
Get:5 http://deb.devuan.org/merged daedalus-updates InRelease [32.5 kB]
Fetched 107 kB in 1s (105 kB/s)
  gnupg2 libnss3-tools
  cloudflare-warp gnupg2 libnss3-tools
0 upgraded, 3 newly installed, 0 to remove and 7 not upgraded.
Need to get 93.4 MB of archives.
After this operation, 441 MB of additional disk space will be used.
#4 2024-01-17 21:36:26
You do not understand what is going on?
Simple explanation: the cloudflareclient only is available for Debian releases, the provider don't know and care about Devuan at all. So if you want something that might possibly work on Devuan you must use the corresponding Debian release name for Daedalus which is Bookworm.
The two dependencies are downloaded from Devuan, so don't worry. If you don't trust the procedure install them beforehand.
Anyhow, there is no warranty that that package will work on Daedalus. You need to determine if it is essential for you, and if it is worth a try. I am showing you whats wrong with the procedure, I haven't used or installed that package, no need for it.
Anyhow, I would try to use a different method anyway: I'd check if I could track down a deb file, download that to /tmp and to install it with dpkg -i and not fiddle with any non Devuan repository into my sources.list.
#5 2024-01-17 22:31:56
deepforest
Thank you for explain i am understand.
Its package not important for me but i am what to know for future about such situations.
But why this two  dependencies take so much space?
#6 2024-01-17 23:41:01
emanym
They don't, gnupg2 is about 400K, libnss-tools some 4.7M (on chimaera),
leaves about 435 MB for the cloudflare package...
#7 2024-01-19 18:26:24
deepforest
Something wrong
root@home:/home/freeartist-devuan# sudo apt-get update && sudo apt-get install cloudflare-warp
Get:2 https://pkg.cloudflareclient.com bookworm InRelease [1,862 B]
Get:3 https://pkg.cloudflareclient.com bookworm/main amd64 Packages [455 B]
Get:4 http://deb.devuan.org/merged daedalus InRelease [42.4 kB]
Get:5 http://deb.devuan.org/merged daedalus-security InRelease [32.5 kB]
Get:6 http://deb.devuan.org/merged daedalus-updates InRelease [32.5 kB]
Get:7 http://deb.devuan.org/merged daedalus-security/main Sources [66.9 kB]
Get:8 http://deb.devuan.org/merged daedalus-security/main amd64 Packages [135 kB]
Get:9 http://deb.devuan.org/merged daedalus-security/main i386 Packages [134 kB]
Fetched 446 kB in 9s (47.3 kB/s)
  linux-headers-6.1.0-13-amd64 linux-headers-6.1.0-13-common linux-image-6.1.0-13-amd64
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Get:1 https://pkg.cloudflareclient.com bookworm/main amd64 cloudflare-warp amd64 2023.10.120-1 [91.9 MB]
Get:2 http://deb.devuan.org/merged daedalus/main amd64 gnupg2 all 2.2.40-1.1 [445 kB]
Get:3 http://deb.devuan.org/merged daedalus/main amd64 libnss3-tools amd64 2:3.87.1-1 [1,054 kB]
Fetched 93.4 MB in 18s (5,100 kB/s)
Selecting previously unselected package gnupg2.
(Reading database ... 220485 files and directories currently installed.)
Preparing to unpack .../gnupg2_2.2.40-1.1_all.deb ...
Unpacking gnupg2 (2.2.40-1.1) ...
Selecting previously unselected package libnss3-tools.
Preparing to unpack .../libnss3-tools_2%3a3.87.1-1_amd64.deb ...
Unpacking libnss3-tools (2:3.87.1-1) ...
Selecting previously unselected package cloudflare-warp.
Preparing to unpack .../cloudflare-warp_2023.10.120-1_amd64.deb ...
Unpacking cloudflare-warp (2023.10.120-1) ...
Setting up gnupg2 (2.2.40-1.1) ...
Setting up libnss3-tools (2:3.87.1-1) ...
Setting up cloudflare-warp (2023.10.120-1) ...
-sh: 1: systemctl: not found
/var/lib/dpkg/info/cloudflare-warp.postinst: 135: systemctl: not found
/var/lib/dpkg/info/cloudflare-warp.postinst: 137: systemctl: not found
Can't exec "systemctl": No such file or directory at /usr/bin/deb-systemd-invoke line 133.
warp-svc is a disabled or a static unit, not starting it.
Processing triggers for desktop-file-utils (0.26-1) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for gnome-menus (3.36.0-1.1) ...
Processing triggers for man-db (2.11.2-2) ...
Processing triggers for mailcap (3.70+nmu1) ...
root@home:/home/freeartist-devuan# cloudflare-warp
bash: cloudflare-warp: command not found
#8 2024-01-19 18:33:37
#9 2024-01-19 19:01:05
deepforest
root@home:/home/freeartist-devuan# warp-cli register
Error: "Unable to connect to CloudflareWARP daemon. Maybe the daemon is not running?"
#10 2024-01-19 19:04:38
deepforest
root@home:/home/freeartist-devuan# rc-service warp-svc.sevice start
 * rc-service: service `warp-svc.sevice' does not exist
systemd is needed?
#11 2024-01-20 04:52:12
hi, check this link to this forum for a sysd to sysv start script converter.
when you're done, check the start and stop levels and adjust to your preference.
https://dev1galaxy.org/viewtopic.php?id=6193
the original website is down...
I hope this helps.
#12 2024-01-20 14:23:16
deepforest
thanks, but i am on openrc
#13 2024-01-21 03:40:21
I also use openrc.
It works, try it.
#14 2024-01-25 17:30:36
deepforest
I also use openrc.
It works, try it.
Thanks and how it works your script trick?
#15 2024-01-25 17:33:45
deepforest
After installation
Found here
root@home:/bin# ls warp*
warp-cli  warp-dex  warp-diag  warp-svc  warp-taskbar
root@home:/bin#
All working good despite install warnings
root@home:/bin# /bin/warp-svc        [^]
freeartist-devuan@home:/bin$ warp-cli register
NOTICE:
Cloudflare only collects limited DNS query and traffic data (excluding payload)
that is sent to our network when you have the app enabled on your device. We
will not sell, rent, share, or otherwise disclose your personal information to
anyone, except as otherwise described in this Policy, without first providing
you with notice and the opportunity to consent. All information is handled in
accordance with our Privacy Policy.
More information is available at:
- https://www.cloudflare.com/application/terms/
- https://www.cloudflare.com/application/privacypolicy/
Accept Terms of Service and Privacy Policy? [y/N] y
Success
freeartist-devuan@home:/bin$ warp-cli connect
Success
freeartist-devuan@home:/bin$ curl https://www.cloudflare.com/cdn-cgi/trace/
fl=636f69
h=www.cloudflare.com
ip=2a09:bac5:5981:18f0::27c:45
ts=1705776501.577
visit_scheme=https
uag=curl/7.88.1
colo=FRA
sliver=none
http=http/2
loc=UA
tls=TLSv1.3
sni=plaintext
warp=on
gateway=off
rbi=off
kex=X25519
freeartist-devuan@home:/bin$ warp=on
#16 2024-01-26 10:55:44
sysd2v-0.3.sh /etc/init.d/<file.name>
