#1 2024-01-16 14:20:47
[ANNOUNCE] xwayland 23.2.4
Just got this in my box.
This release contains fixes for the issues reported in today's security
advisory: https://lists.x.org/archives/xorg/2024- … 61525.html
* CVE-2023-6816
* CVE-2024-0229
* CVE-2024-21885
* CVE-2024-21886
* CVE-2024-0408
* CVE-2024-0409
Additionally, it also contains several other fixes for glamor, libEI support,
and FreeBSD.
Jan Beich (2):
       os: Use LOCAL_PEERCRED to determine local client PID on FreeBSD
       os: Use KERN_PROC_ARGS to determine client command on DragonFly and FreeBSD
José Expósito (2):
       Xi: do not keep linked list pointer during recursion
       Bump version to 23.2.4
Michel Dänzer (3):
       glamor: Don't override source alpha to 1.0 if it's used for blending
       glamor: Make glamor_set_alu take a DrawablePtr
       glamor: Fall back for mixed depth 24/32 in glamor_set_alu
Olivier Fourdan (3):
       xwayland: Pass the correct oeffis device types
       glx: Call XACE hooks on the GLX buffer
       ephyr,xwayland: Use the proper private key for cursor
Peter Hutterer (10):
       Xi: require a pointer and keyboard device for XIAttachToMaster
       dix: don't allow for devices with 0 axes
       xwayland: override the XTest sendEventsProc for all devices
       dix: initialize the XTest sendEventsProc for all devices
       dix: allocate enough space for logical button maps
       dix: Allocate sufficient xEvents for our DeviceStateNotify
       dix: fix DeviceStateNotify event calculation
       Xi: when creating a new ButtonClass, set the number of buttons
       Xi: flush hierarchy events after adding/removing master devices
       dix: when disabling a master, float disabled slaved devices too
git tag: xwayland-23.2.4
https://xorg.freedesktop.org/archive/in … 2.4.tar.xz
SHA256: a99e159b6d0d33098b3b6ab22a88bfcece23c8b9d0ca72c535c55dcb0681b46b  xwayland-23.2.4.tar.xz
SHA512: ac3ff208cbef5bbe4637c335cfda226489c93b0a3768f2f4fb0201c588485ede38262fbce77ef1425b3d2a0be61b6580df53341c7b95e6072c8b6371ad29d187  xwayland-23.2.4.tar.xz
PGP:  https://xorg.freedesktop.org/archive/in … tar.xz.sig
