#1 2024-01-16 14:17:34
X.Org Security Advisory: X.Org X server and Xwayland
Just got this in my box.
Good to see X.Org at work.
Issues in X.Org X server prior to 21.1.11 and Xwayland prior to 23.2.4
Multiple issues have been found in the X server and Xwayland implementations
published by X.Org for which we are releasing security fixes for in
xorg-server-21.1.11 and xwayland-23.2.4.
1) CVE-2023-6816 can be triggered by passing an invalid array index to DeviceFocusEvent or ProcXIQueryPointer.
2) CVE-2024-0229 can be triggered if a device has both a button and a key class and zero buttons.
3) CVE-2024-21885 can be triggered if a device with a given ID was removed and a new device with the same ID added both in the same operation.
4) CVE-2024-21886 can be triggered by disabling a master device with disabled slave devices.
5) CVE-2024-0409 can be triggered by enabling SELinux xserver_object_manager and running a client.
6) CVE-2024-0408 can be triggered by enabling SELinux xserver_object_manager and creating a GLX PBuffer.
1) CVE-2023-6816: Heap buffer overflow in DeviceFocusEvent and ProcXIQueryPointer
Introduced in: xorg-server-1.13.0 (2012)
Fixed in: xorg-server-21.1.11 and xwayland-23.2.4
Fix: https://gitlab.freedesktop.org/xorg/xse … 3c58a9e7e3
Found by: Jan-Niklas Sohn working with Trend Micro Zero Day Initiative
Both DeviceFocusEvent and the XIQueryPointer reply contain a bit for
each logical button currently down. Buttons can be arbitrarily mapped to
any value up to 255 but the X.Org Server was only allocating space for the
device's number of buttons, leading to a heap overflow if a bigger value
was used.
xorg-server-21.1.11 and xwayland-23.2.4 have been patched to fix this issue.
2) CVE-2024-0229: Reattaching to different master device may lead to out-of-bounds memory access
Introduced in: xorg-server-1.1.1 (2006)
Fixes:
  - https://gitlab.freedesktop.org/xorg/xse … 636109d6a5
  - https://gitlab.freedesktop.org/xorg/xse … cde53553d5
  - https://gitlab.freedesktop.org/xorg/xse … e0d5981b74
If a device has both a button class and a key class and numButtons is
zero, we can get an out-of-bounds write due to event under-allocation in
the DeliverStateNotifyEvent function.
3) CVE-2024-21885: Heap buffer overflow in XISendDeviceHierarchyEvent
Introduced in: xorg-server-1.10.0 (2011)
Fix: https://gitlab.freedesktop.org/xorg/xse … dce503cbd1
The XISendDeviceHierarchyEvent() function allocates space to store up
to MAXDEVICES (256) xXIHierarchyInfo structures in info.
If a device with a given ID was removed and a new device with the same
ID added both in the same operation, the single device ID will lead to
two info structures being written to info.
Since this case can occur for every device ID at once, a total of two
times MAXDEVICES info structures might be written to the allocation,
leading to a heap buffer overflow.
4) CVE-2024-21886: Heap buffer overflow in DisableDevice
Fixes:
  - https://gitlab.freedesktop.org/xorg/xse … 54dd0ce36b
  - https://gitlab.freedesktop.org/xorg/xse … 10cc07c3a8
The DisableDevice() function is called whenever an enabled device
is disabled and it moves the device from the inputInfo.devices linked
list to the inputInfo.off_devices linked list.
However, its link/unlink operation has an issue during the recursive
call to DisableDevice() due to the prev pointer pointing to a
removed device.
This issue leads to a length mismatch between the total number of
devices and the number of device in the list, leading to a heap
overflow and, possibly, to local privilege escalation.
5) CVE-2024-0409: SELinux context corruption
Introduced in: xorg-server-1.16.0 (2014)
Fix: https://gitlab.freedesktop.org/xorg/xse … ea702c94f7
Found by: Olivier Fourdan
The Xserver uses the mechanism of "privates" to store additional data to its
own objects, each private has an associate "type". Each private is allocated
for the relevant size of memory that is declared at creation.
The cursor structure in the Xserver goes as far as having two keys, one for
the cursor itself and another one for the bits that make the cursor shape.
XSELINUX also uses privates but it's a bit of a special case because it uses
the same privates keys for all different objects.
What happens here is that the cursor code in both Xephyr and Xwayland uses the
wrong type of private at creation, using the cursor bits type with the cursor
private and when initiating the cursor, the overwrites the XSELINUX context.
6) CVE-2024-0408: SELinux unlabeled GLX PBuffer
Fix: https://gitlab.freedesktop.org/xorg/xse … fe5e15dac3
Found by: Olivier Fourdan and Donn Seeley
The XSELINUX code in the Xserver labels the X resources based on a hook. What
happens here is that the GLX PBuffer code does not call that XACE hook when
creating the buffer, so it remains unlabeled, and when the client issues
another request to access that resource (as here with a GetGeometry) or even
when it creates another resource which needs to access that buffer (such as a
GC), the XSELINUX code will try to use an object that was never labeled and
crash because the SID is NULL.
