#1 2024-01-15 08:54:19
jue-gen
[SOLVED] libvirt / Virtual Machine Manager als root?
Hello everyone, what do you think?:
For example, when I start Heads with libvirt / Virtual Machine Manager, the root password is requested. Is that ok or should it be set up so that libvirt / Virtual Machine Manager can be started as a normal user?
#2 2024-01-23 18:38:41
FOSSenjoyer
Re: [SOLVED] libvirt / Virtual Machine Manager als root?
Should work fine, you have added your user at the libvirt group ?
usermod -G libvirt -a $USER
#3 2024-01-23 20:02:42
jue-gen
Yes, thank you very much FOSSenjoyer! I much prefer it that way, of course.
#4 2024-01-24 12:09:19
Also ad your user to
 libvirt-qemu
group
adduser username libvirt-qemu
#5 2024-01-24 12:24:53
jue-gen
Yes, done, stopAI. Does that have any additional benefit?
#6 2024-01-24 16:47:48
In order to manage virtual machines as a regular user, that user needs to be added to the that group. Members of the libvirt group have passwordless access to the RW daemon socket by default.
#7 2024-01-24 17:13:34
jue-gen
Thank you smile
