#1 2024-01-09 15:15:50
bigcat
suspend with nvidia drivers
Greetings,
I am using a recently installed daedalus system with nvidia drivers.   The system cannot be suspended, with the following message in syslog:
loginctl[15454]: Failed to suspend system via elogind: Connection timed out
I spent about an hour looking for solutions.  It looks like a lot of people have the same problem.
Posting here just in case someone knows what's going on.   The driver version is nvidia-tesla-470.
Thanks for any suggestions!
Edit: there was one report that systemd does suspend successfully.  I cannot verify that since all my machines are on devuan now. I am skeptical about that claim because both systemd and elogind are likely to use the same mechanism to signal the suspend.
#2 2024-01-11 02:15:58
UnixMan1230
Re: suspend with nvidia drivers
NVIDIA has historically not played nice with suspend. I have an old T61p that has NVIDIA graphics, and it doesn't suspend correctly, either.
"Less is only more when it's what you're looking for" -Unknown
"Who do I need to fuck to get standard font size and panel options?" - Linus Torvalds
#3 2024-01-12 17:06:48
nixer
For what it is worth, I have an nvidia card and I use the same tesla.470 series driver.  I have both hibernate and suspend working fine on a ceres, excalibur, and daedalus systems.  I use them both every day.  I don't recall making any config changes other than what is mentioned here:
https://dev1galaxy.org/viewtopic.php?id=5973
#4 2024-01-13 23:40:22
bigcat
Thanks All.
