#1 2023-12-17 20:30:07
[SOLVED] Video display not working, via rockpro64
I followed the wiki on rockpro64:
https://wiki.pine64.org/wiki/ROCKPro64_ … ses#Debian
However this error happens:
https://wiki.pine64.org/wiki/ROCKPro64# … _on_Debian
How do I fix this?
I see the guide, but if I can't get a video display, how the frick do I  fix this issue by doing this:
echo governor_simpleondemand >> /etc/initramfs-tools/modules
update-initramfs -u -k $(uname -r)
I mean if I can't even see the display, then how can I even do that.
Answers anyone? Could use them.
#2 2023-12-18 06:51:53
Re: [SOLVED] Video display not working, via rockpro64
the guide assumes you can login via serial to perform corrective action
these might provide food for thought
(grabbed semi-randomly, ymmv)
https://forum.pine64.org/showthread.php?tid=6387
https://wiki.pine64.org/wiki/ROCKPro64_ … er_Circuit
#3 2023-12-18 20:31:35
I guess then, do I really need that serial console to get video output? And what do I need to make it function properly period.
Thoughts?
I don't have a usb serial console currently as a heads up.
#4 2023-12-19 12:17:07
have you had video success with any other distributions(thinking hardware-check here)?
https://wiki.pine64.org/wiki/ROCKPro64_ … e_Releases
say(random-pick) perhaps TwisterOS?
https://twisteros.com/twisterarmbian.html
#5 2023-12-19 12:32:14
If you have the disk image you can mount that on som other system and run that update command there. Or even patch the initrd directly (unpack, patch, pack).
#6 2023-12-19 16:53:33
Oh, well I don't know how to do this currently... patching initrd directly, etc on another system.
Although, I won't have access till friday or later.
I have not tried any other distro yet though.
#7 2024-01-07 05:47:42
Actually, I think I found out why I kept failing... I forgot to make an unused partition with 30MB
#8 2024-01-09 05:21:52
Would not making an unused partition with 30MB cause it not to boot properly? meaning no display?
Seems that was the problem, I only used 99% of the disk and I had no issues from there.
