#1 2023-12-13 05:32:38
X.Org Security Advisory: Issues in X.Org X server
Just got this in my inbox.
Good to see that things 'X11' are rolling along steadily.
X.Org Security Advisory: December 13, 2023
Issues in X.Org X server prior to 21.1.10 and Xwayland prior to 23.2.3
Multiple issues have been found in the X server and Xwayland implementations
published by X.Org for which we are releasing security fixes for in
xorg-server-21.1.10 and xwayland-23.2.3.
1) CVE-2023-6377 can be triggered by forcing a logical device change on a device
with buttons which will result in an out-of-bounds memory write.
2) CVE-2023-6478 can be triggered by sending a specially crafted
request RRChangeProviderProperty or RRChangeOutputProperty. This will trigger
an integer overflow and lead to disclosure of information.
1) CVE-2023-6377: X.Org server: Out-of-bounds memory write in XKB button actions
Introduced in: xorg-server-1.6.0 (2009)
Fixed in: xorg-server-21.1.10 and xwayland-23.2.3
Fix: https://gitlab.freedesktop.org/xorg/xse … 4f93810afd
Found by: Jan-Niklas Sohn working with Trend Micro Zero Day Initiative
A device has XKB button actions for each button on the device. When a logical
device switch happens (e.g. moving from a touchpad to a mouse), the server
re-calculates the information available on the respective master device
(typically the Virtual Core Pointer). This re-calculation only allocated enough
memory for a single XKB action rather instead of enough for the newly active
physical device's number of button. As a result, querying or changing the XKB
button actions results in out-of-bounds memory reads and writes.
This may lead to local privilege escalation if the server is run as root or
remote code execution (e.g. x11 over ssh).
xorg-server-21.1.10 and xwayland-23.2.3 have been patched to fix this issue.
2) CVE-2023-6478: X.Org server: Out-of-bounds memory read in RRChangeOutputProperty and RRChangeProviderProperty
Introduced in: xorg-server-1.4.0 (2007) and xorg-server-1.13.0 (2012), respectively
Fix: https://gitlab.freedesktop.org/xorg/xse … fff81ad632
This fixes an OOB read and the resulting information disclosure.
Length calculation for the request was clipped to a 32-bit integer. With
the correct stuff->nUnits value the expected request size was
truncated, passing the REQUEST_FIXED_SIZE check.
The server then proceeded with reading at least stuff->nUnits bytes
(depending on stuff->format) from the request and stuffing whatever it
finds into the property. In the process it would also allocate at least
stuff->nUnits bytes, i.e. 4GB.
See also CVE-2022-46344 where this issue was fixed for other requests.
