#1 2023-12-10 11:47:37
nosysd_absolutist
[SOLVED] Can't get latest kernel. 403: access denied.
Trying to do a dist-upgrade, being told I don't have access to download the kernel?
Err:1 https://pkgmaster.devuan.org/merged daedalus/main amd64 linux-image-6.1.0-14-amd64 amd64 6.1.64-1
  403  Access denied - broken package
Err:2 https://pkgmaster.devuan.org/merged daedalus/main amd64 linux-image-amd64 amd64 6.1.64-1
E: Failed to fetch https://deb.debian.org/debian/pool/main/l/linux-signed-amd64/linux-image-6.1.0-14-amd64_6.1.64-1_amd64.deb  403  Access denied - broken package
E: Failed to fetch https://deb.debian.org/debian/pool/main/l/linux-signed-amd64/linux-image-amd64_6.1.64-1_amd64.deb  403  Access denied - broken package
#2 2023-12-10 12:31:11
Re: [SOLVED] Can't get latest kernel. 403: access denied.
As the message says: package is broken. There seems to be an issue with the ext4 file system.
https://micronews.debian.org/2023/1702150551.html
You will have to wait for the fix ...
#3 2023-12-10 13:31:18
nosysd_absolutist
I put in the search terms and nothing came up, so thank you for letting me know.
I'll leave the thread open until I can properly update.
#4 2023-12-11 12:30:01
New kernel (6.1.0-15) is available by now.
#5 2023-12-16 08:07:19
nosysd_absolutist
Need to restart to be sure but it appears to have installed successfully. Closing thread as solved.
#6 2023-12-16 22:51:14
James1138
Just wondering... can new kernel (6.1.0-15) that is available be installed on Devuan 3?
