#1 2023-12-09 23:02:56
SlySven
[SOLVED] Daedalus nvidia borkage with nvidia-driver 525.147.05-4~deb12u1
I just did an apt update, apt upgrade and my Daedalus system has gotten it's Nvidia graphics packages messed up - according to aptitude this seems to be because most of the NVidia packages have been updated to 525.147.05-4~deb12u1 but firmware-nvidia-gsp in particular (but nvidia-kernel-dkms and nvidia-settings also look suspicious) is not available at that version for that Devuan version (they seem to be back at  525.125.06-1~deb12u1):
stephen@Ripley:~$ sudo dpkg-query -l | grep -i nvidia
ii  firmware-nvidia-gsp                           525.125.06-1~deb12u1                    amd64        NVIDIA GSP firmware
ii  glx-alternative-nvidia                        1.2.2                                   amd64        allows the selection of NVIDIA as GLX provider
ii  libcuda1:amd64                                525.147.05-4~deb12u1                    amd64        NVIDIA CUDA Driver Library
ri  libegl-nvidia0:amd64                          525.147.05-4~deb12u1                    amd64        NVIDIA binary EGL library
ri  libgl1-nvidia-glvnd-glx:amd64                 525.147.05-4~deb12u1                    amd64        NVIDIA binary OpenGL/GLX library (GLVND variant)
ri  libgles-nvidia1:amd64                         525.147.05-4~deb12u1                    amd64        NVIDIA binary OpenGL|ES 1.x library
ri  libgles-nvidia2:amd64                         525.147.05-4~deb12u1                    amd64        NVIDIA binary OpenGL|ES 2.x library
ii  libglx-nvidia0:amd64                          525.147.05-4~deb12u1                    amd64        NVIDIA binary GLX library
ii  libnvcuvid1:amd64                             525.147.05-4~deb12u1                    amd64        NVIDIA CUDA Video Decoder runtime library
ri  libnvidia-allocator1:amd64                    525.147.05-4~deb12u1                    amd64        NVIDIA allocator runtime library
ii  libnvidia-cfg1:amd64                          525.147.05-4~deb12u1                    amd64        NVIDIA binary OpenGL/GLX configuration library
ri  libnvidia-egl-gbm1:amd64                      1.1.0-2                                 amd64        GBM EGL external platform library for NVIDIA
ri  libnvidia-egl-wayland1:amd64                  1:1.1.10-1                              amd64        Wayland EGL External Platform library -- shared library
ii  libnvidia-eglcore:amd64                       525.147.05-4~deb12u1                    amd64        NVIDIA binary EGL core libraries
ii  libnvidia-encode1:amd64                       525.147.05-4~deb12u1                    amd64        NVENC Video Encoding runtime library
ii  libnvidia-glcore:amd64                        525.147.05-4~deb12u1                    amd64        NVIDIA binary OpenGL/GLX core libraries
ii  libnvidia-glvkspirv:amd64                     525.147.05-4~deb12u1                    amd64        NVIDIA binary Vulkan Spir-V compiler library
ii  libnvidia-ml1:amd64                           525.147.05-4~deb12u1                    amd64        NVIDIA Management Library (NVML) runtime library
ii  libnvidia-ptxjitcompiler1:amd64               525.147.05-4~deb12u1                    amd64        NVIDIA PTX JIT Compiler library
ii  libnvidia-rtcore:amd64                        525.147.05-4~deb12u1                    amd64        NVIDIA binary Vulkan ray tracing (rtcore) library
ii  nvidia-alternative                            525.147.05-4~deb12u1                    amd64        allows the selection of NVIDIA as GLX provider
rU  nvidia-driver                                 525.147.05-4~deb12u1                    amd64        NVIDIA metapackage
ri  nvidia-driver-bin                             525.147.05-4~deb12u1                    amd64        NVIDIA driver support binaries
ri  nvidia-driver-libs:amd64                      525.147.05-4~deb12u1                    amd64        NVIDIA metapackage (OpenGL/GLX/EGL/GLES libraries)
ri  nvidia-egl-common                             525.147.05-4~deb12u1                    amd64        NVIDIA binary EGL driver - common files
ri  nvidia-egl-icd:amd64                          525.147.05-4~deb12u1                    amd64        NVIDIA EGL installable client driver (ICD)
ii  nvidia-installer-cleanup                      20220217+3~deb12u1                      amd64        cleanup after driver installation with the nvidia-installer
ii  nvidia-kernel-common                          20220217+3~deb12u1                      amd64        NVIDIA binary kernel module support files
ii  nvidia-kernel-dkms                            525.125.06-1~deb12u1                    amd64        NVIDIA binary kernel module DKMS source
ii  nvidia-kernel-support                         525.147.05-4~deb12u1                    amd64        NVIDIA binary kernel module support files
ii  nvidia-legacy-check                           525.147.05-4~deb12u1                    amd64        check for NVIDIA GPUs requiring a legacy driver
ii  nvidia-modprobe                               535.54.03-1~deb12u1                     amd64        utility to load NVIDIA kernel modules and create device nodes
ii  nvidia-persistenced                           525.85.05-1                             amd64        daemon to maintain persistent software state in the NVIDIA driver
ri  nvidia-settings                               525.125.06-1~deb12u1                    amd64        tool for configuring the NVIDIA graphics driver
ii  nvidia-smi                                    525.147.05-4~deb12u1                    amd64        NVIDIA System Management Interface
ii  nvidia-support                                20220217+3~deb12u1                      amd64        NVIDIA binary graphics driver support files
ii  nvidia-vdpau-driver:amd64                     525.147.05-4~deb12u1                    amd64        Video Decode and Presentation API for Unix - NVIDIA driver
ii  nvidia-vulkan-common                          525.147.05-4~deb12u1                    amd64        NVIDIA Vulkan driver - common files
ii  nvidia-vulkan-icd:amd64                       525.147.05-4~deb12u1                    amd64        NVIDIA Vulkan installable client driver (ICD)
ri  xserver-xorg-video-nvidia                     525.147.05-4~deb12u1                    amd64        NVIDIA binary Xorg driver
Also compare the outputs of:
and look closely at the package versions available for "daedulus"
Who do I contact to request a fixup? smile
#2 2023-12-18 21:50:45
SlySven
Re: [SOLVED] Daedalus nvidia borkage with nvidia-driver 525.147.05-4~deb12u1
An update a week later (in the meantime I had been getting FreeBSD going on the same PC) fixed things and the out of step packages have been updated:
stephen@Ripley:~$ sudo dpkg-query -l | grep nvidia
ii  firmware-nvidia-gsp                           525.147.05-4~deb12u1                    amd64        NVIDIA GSP firmware
ii  libegl-nvidia0:amd64                          525.147.05-4~deb12u1                    amd64        NVIDIA binary EGL library
ii  libgl1-nvidia-glvnd-glx:amd64                 525.147.05-4~deb12u1                    amd64        NVIDIA binary OpenGL/GLX library (GLVND variant)
ii  libgles-nvidia1:amd64                         525.147.05-4~deb12u1                    amd64        NVIDIA binary OpenGL|ES 1.x library
ii  libgles-nvidia2:amd64                         525.147.05-4~deb12u1                    amd64        NVIDIA binary OpenGL|ES 2.x library
ii  libnvidia-allocator1:amd64                    525.147.05-4~deb12u1                    amd64        NVIDIA allocator runtime library
ii  libnvidia-egl-gbm1:amd64                      1.1.0-2                                 amd64        GBM EGL external platform library for NVIDIA
ii  libnvidia-egl-wayland1:amd64                  1:1.1.10-1                              amd64        Wayland EGL External Platform library -- shared library
ii  nvidia-driver                                 525.147.05-4~deb12u1                    amd64        NVIDIA metapackage
ii  nvidia-driver-bin                             525.147.05-4~deb12u1                    amd64        NVIDIA driver support binaries
ii  nvidia-driver-libs:amd64                      525.147.05-4~deb12u1                    amd64        NVIDIA metapackage (OpenGL/GLX/EGL/GLES libraries)
ii  nvidia-egl-common                             525.147.05-4~deb12u1                    amd64        NVIDIA binary EGL driver - common files
ii  nvidia-egl-icd:amd64                          525.147.05-4~deb12u1                    amd64        NVIDIA EGL installable client driver (ICD)
ii  nvidia-kernel-dkms                            525.147.05-4~deb12u1                    amd64        NVIDIA binary kernel module DKMS source
ii  nvidia-settings                               525.125.06-1~deb12u1                    amd64        tool for configuring the NVIDIA graphics driver
ii  xserver-xorg-video-nvidia                     525.147.05-4~deb12u1                    amd64        NVIDIA binary Xorg driver
#3 2023-12-19 08:53:12
Good to know! I was holding off updating one of my machines. Thanks!
EDIT: just updated and it seems to be working 100% Kernel 6.1.0-16-amd64 and Nvidia version: 525.147.05
Yayy!
