#1 2023-11-19 00:53:20
durham
devuan daedalus: nothing is running in wine
Nothing is running in wine. I've not used wine in devuan in a while so I am not sure what changed. That said, I recently finally got around to an upgrade to the latest Stable version of devuan.
The error message seems the same for all programs I've tried to run (in this next, an attempt to run guild wars, a windows game that up to how has always worked fine in wine):
~ $ wine Gw.exe -bmp -fps 30
0024:err:module:import_dll Library zlib1.dll (which is needed by L"C:\\windows\\system32\\USER32.dll") not found
0024:err:module:import_dll Library USER32.dll (which is needed by L"Z:\\home\\bob\\win_hold\\proggy\\Guild Wars\\Gw.exe") not found
0024:err:module:import_dll Library zlib1.dll (which is needed by L"C:\\windows\\system32\\user32.dll") not found
0024:err:module:import_dll Library user32.dll (which is needed by L"C:\\windows\\system32\\msacm32.dll") not found
0024:err:module:import_dll Library msacm32.dll (which is needed by L"C:\\windows\\system32\\WINMM.dll") not found
0024:err:module:import_dll Library user32.dll (which is needed by L"C:\\windows\\system32\\combase.dll") not found
0024:err:module:import_dll Library combase.dll (which is needed by L"C:\\windows\\system32\\ole32.dll") not found
0024:err:module:import_dll Library user32.dll (which is needed by L"C:\\windows\\system32\\ole32.dll") not found
0024:err:module:import_dll Library ole32.dll (which is needed by L"C:\\windows\\system32\\WINMM.dll") not found
0024:err:module:import_dll Library user32.dll (which is needed by L"C:\\windows\\system32\\WINMM.dll") not found
0024:err:module:import_dll Library WINMM.dll (which is needed by L"Z:\\home\\bob\\win_hold\\proggy\\Guild Wars\\Gw.exe") not found
0024:err:module:import_dll Library user32.dll (which is needed by L"C:\\windows\\system32\\shlwapi.dll") not found
0024:err:module:import_dll Library shlwapi.dll (which is needed by L"C:\\windows\\system32\\SHELL32.dll") not found
0024:err:module:import_dll Library user32.dll (which is needed by L"C:\\windows\\system32\\SHELL32.dll") not found
0024:err:module:import_dll Library SHELL32.dll (which is needed by L"Z:\\home\\bob\\win_hold\\proggy\\Guild Wars\\Gw.exe") not found
0024:err:module:import_dll Library user32.dll (which is needed by L"C:\\windows\\system32\\imm32.dll") not found
0024:err:module:import_dll Library imm32.dll (which is needed by L"C:\\windows\\system32\\COMCTL32.dll") not found
0024:err:module:import_dll Library user32.dll (which is needed by L"C:\\windows\\system32\\COMCTL32.dll") not found
0024:err:module:import_dll Library COMCTL32.dll (which is needed by L"Z:\\home\\bob\\win_hold\\proggy\\Guild Wars\\Gw.exe") not found
0024:err:module:import_dll Library ole32.dll (which is needed by L"C:\\windows\\system32\\OLEAUT32.dll") not found
0024:err:module:import_dll Library user32.dll (which is needed by L"C:\\windows\\system32\\OLEAUT32.dll") not found
0024:err:module:import_dll Library OLEAUT32.dll (which is needed by L"Z:\\home\\bob\\win_hold\\proggy\\Guild Wars\\Gw.exe") not found
0024:err:module:import_dll Library ole32.dll (which is needed by L"Z:\\home\\bob\\win_hold\\proggy\\Guild Wars\\Gw.exe") not found
0024:err:module:import_dll Library user32.dll (which is needed by L"C:\\windows\\system32\\MSACM32.dll") not found
0024:err:module:import_dll Library ole32.dll (which is needed by L"C:\\windows\\system32\\winmm.dll") not found
0024:err:module:import_dll Library user32.dll (which is needed by L"C:\\windows\\system32\\winmm.dll") not found
0024:err:module:import_dll Library winmm.dll (which is needed by L"C:\\windows\\system32\\MSACM32.dll") not found
0024:err:module:import_dll Library MSACM32.dll (which is needed by L"Z:\\home\\bob\\win_hold\\proggy\\Guild Wars\\Gw.exe") not found
0024:err:module:LdrInitializeThunk Importing dlls for L"Z:\\home\\bob\\win_hold\\proggy\\Guild Wars\\Gw.exe" failed, status c0000135
bob@moonshadow:~ $ MESA-INTEL: warning: Haswell Vulkan support is incomplete
The files are there. Not sure why wine can't find file <whatever>when fie <whatever> is right there.
Googling indicates that others have had this problem, but the solutions were unclear, though many results indicated that installing winetricks would fix it.
I then installed winetricks. Not sure what the difference is. Still nothing runs, so winetricks is not the trick? I'm out of ideas. Can anyone advise, please?
Thank you.
A dangerous technology is one that is available only to an elite group  -- George M. Ewing, Analog, April 1977
#2 2023-11-19 12:24:09
Re: devuan daedalus: nothing is running in wine
Are there files in "$HOME/.wine/drive_c/windows/system32" ?
I would proabaly start with a fresh wine setup.
$ mv .wine .wine_old      # backup
$ winecfg
#3 2023-11-20 03:14:37
czeekaj
try using wine-staging direct from wine repos. Follow instructions for debian installation.
#4 2023-11-20 19:14:55
durham
Thank you for the replies.
The "missing" files are there. Checking the file from the first error message:
 $ find $HOME -type f | grep -i "zlib1\.dll"
/home/bob/.wine/drive_c/windows/system32/zlib1.dll
In the meantime, I tried something that I knew would not work and it worked. I have multiple distros on this computer, so I, still in Devuan, ran the wine from the Slackware install. It runs fine.
I will check out the staging thing. Thank you.
EDIT: staging version from winehq.org works. Yay!  Thank you.
