#1 2023-11-18 22:46:27
Anyone know how to make a usb mouse work?
I have a usb wireless mouse for specific purposes, but it refuses to start on devuan. I wondered, if someone could give me a bunch of ways to do so.
I have yet to get it working. Its possible that debian did something stupid that makes this complicated... idk.
I have no problem on Hyperbola with this issue, its just annoying as can be on devuan though.
What packages typically does it require to get a usb mouse working such as M650 L LEFT?
Do i need to modprobe something? I am using openrc, so if you have sysvinit ideas, adapt them please.
#2 2023-11-18 22:49:11
UnixMan1230
Re: Anyone know how to make a usb mouse work?
well, desktop environment can make a pretty big difference. Have you checked to see if the USB mouse works at the greeter? (If its a mouse-enabled greeter like slick or sddm?) What DE are you using?
"Less is only more when it's what you're looking for" -Unknown
"Who do I need to fuck to get standard font size and panel options?" - Linus Torvalds
#3 2023-11-19 09:34:11
I have to click a button to get mine working/switched on.
#4 2023-11-19 10:55:18
3@localhost:~> lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 002: ID 1ea7:0066 SHARKOON Technologies GmbH [Mediatrack Edge Mini Keyboard]
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 002: ID 1ea7:0066 SHARKOON Technologies GmbH [Mediatrack Edge Mini Keyboard - usb wireless mouse receiver
#5 2023-11-19 12:05:26
Is the mouse's batterie charged?
Can't remember haveing mouse problems the past decade or so. Would you mind sharing the manufacturer?
#6 2023-11-20 05:38:48
Logitech, the battery is charged, it works on Hyperbola as I said above, but not devuan.
Although, lsusb isn't available either... which is weird.
#7 2023-11-20 05:45:42
Unplug the mouse, run "tail -f /var/log/syslog > capture.log", then plug in the mouse and then type ctrl-C to stop the tail. Then drop in the log into a code box here.
#8 2023-11-21 00:34:54
Without the quotes, it said permission denied for some reason. No idea why.
#9 2023-11-21 10:05:01
PedroReina
Was it run as root?
#10 2023-11-21 16:37:01
I own a small wireless mouse by Trust, item no.  20322-09. It runs on 2 AAA cells. The Bluetooth? dongle is stored inside the mouse when its not used. This mouse has an on/off switch.
I am mainly using it on my laptop. It worked out of the box with Chimaera and Daedalus, in both cases LightDM/Cinnamon as DE. No special action required. I can start the laptop, and plug in the mouse when I am logged in. It works.
#11 2024-01-24 01:36:34
I should probably mention, I gave up. But if your curious as to if I ran root, no.
Also, no idea of wayland was causing the problem or not... but its weird, Hyperbola 0.4.4, a lot less packages and by default the usb mouse worked, but in Devuan 12 which has many newer packages, not so much.
Its bonkers...
Maybe I needed xfce or mate though?
Idk... so weird.
But since I stopped gaming again, it matters not.
