#1 2023-11-14 21:09:04
jemadux
experimental repo and some questions
Lets talk about some minor things .
As we know dev1 gnu / linux on debian gnu /linux the only difference is the init .
Will I have different approach if I use debian with different init system like this [1]
If I want to install something from experimental repository of debian is that good idea to
mix the /apt/sources.list with experimental ones ?
[1] https://wiki.debian.org/Init#Changing_t … ation_time
Dev1 Stable | openrc | MATE
Greetings from Greece
#2 2023-11-14 21:52:36
Re: experimental repo and some questions
I have done, thankfully the app didn't require a system upgrade.
I add it to my sources list, used it to install the package and then commented(#) the line, but left it there for easy reference.
