#1 2023-10-19 16:42:41
amaro
apt autoremove breaks suspend and network-manager autoconnect
After new 'chimaera' install and setting everything to my needs I did 'apt autoremove'. Upon reboot I got 2 issues - 1) after suspend I get a blank screen and 2) 'network-manager' does not autoconnect to the wi-fi.
Here is the list of packages the 'autoremove' command cleaned
      coinor-libcbc3 coinor-libcgl1 coinor-libclp1 coinor-libcoinmp1v5 coinor-libcoinutils3v5 coinor-libosi1v5
      espeak-ng-data exfalso fonts-font-awesome fonts-lato fonts-opensymbol gimp-data gir1.2-atspi-2.0
      gir1.2-gtksource-3.0 gir1.2-wnck-3.0 libabw-0.1-1 libamd2 libatk-adaptor libbabl-0.1-0
      libboost-filesystem1.74.0 libboost-locale1.74.0 libboost-thread1.74.0 libbrlapi0.8 libcamd2 libccolamd2
      libcdr-0.1-1 libcholmod3 libclucene-contribs1v5 libcmis-0.5-5v5 libcolamd2 libdotconf0 libe-book-0.1-1
      libeot0 libepubgen-0.1-1 libespeak-ng1 libetonyek-0.1-1 libexttextcat-2.0-0 libexttextcat-data
      libfreehand-0.1-1 libfreeimage3 libgegl-0.4-0 libgegl-common libgexiv2-2 libgimp2.0 libgpgmepp6 libheif1
      libip4tc2 libip6tc2 libjuh-java libjurt-java libjxr0 liblangtag-common liblangtag1 liblibreoffice-java
      libmetis5 libmhash2 libmspub-0.1-1 libmwaw-0.3-3 libmythes-1.2-0 libnumbertext-1.0-0 libnumbertext-data
      libodfgen-0.1-1 libopengl0 liborcus-0.16-0 liborcus-parser-0.16-0 libpagemaker-0.0-0 libpcaudio0
      libqrcodegencpp1 libqxp-0.0-0 libraptor2-0 librasqal3 libraw20 librevenge-0.0-0 libridl-java libsonic0
      libspeechd2 libstaroffice-0.0-0 libsuitesparseconfig5 libumfpack5 libuno-cppu3 libuno-cppuhelpergcc3-3
      libuno-purpenvhelpergcc3-3 libuno-sal3 libuno-salhelpergcc3-3 libunoloader-java libvisio-0.1-1
      libwpd-0.10-10 libwpg-0.3-3 libwps-0.4-4 libxmlsec1 libxmlsec1-nss libyajl2 libzmf-0.0-0 lp-solve
      node-normalize.css perl-tk python3-brlapi python3-feedparser python3-louis python3-musicbrainzngs
      python3-pyatspi python3-pyinotify python3-speechd python3-xdg sound-icons speech-dispatcher-audio-plugin
      sphinx-rtd-theme-common uno-libs-private ure xbrlapi xkbset xsane-common
How to find out which packages need to be reinstalled to solve these issues?
Thank you in advance!
#2 2023-10-19 23:23:37
Re: apt autoremove breaks suspend and network-manager autoconnect
I wonder, how you will reinstall any of those packages without wifi.
I can only see a few packages in that list that may be required, but you must have removed a package that you rely on.
A re-install of the OS may be easier, then just remove the accessible apps you don't want. One at a time... keep a list...
the system keeps a log here...
/var/log/dpkg.log
/var/log/apt/history.log
use cat or tail to see in a terminal/console
