#1 2023-10-19 16:10:50
deepforest
Digital Camera not shown in Devices, Thunar
Previously when i am plug my camera i see it in Device section
But after recently updates i do not see it
freeartist-devuan@home:~/Downloads$ sudo apt install gvfs
gvfs is already the newest version (1.50.3-1).
freeartist-devuan@home:~/Downloads$ sudo apt install gvfs-gphoto2
E: Unable to locate package gvfs-gphoto2
Same NOT SHOWN
https://docs.xfce.org/xfce/thunar/unix- … ile_system
freeartist-devuan@home:~/Downloads$ sudo apt install gvfs-backends
  libgdata-common libgdata22 libgoa-1.0-0b libgoa-1.0-common libimobiledevice6 libplist3 libusbmuxd6 psmisc usbmuxd
Suggested packages:
  bluez-obexd samba-common libusbmuxd-tools
  gvfs-backends libgdata-common libgdata22 libgoa-1.0-0b libgoa-1.0-common libimobiledevice6 libplist3 libusbmuxd6
  psmisc usbmuxd
0 upgraded, 10 newly installed, 0 to remove and 0 not upgraded.
Need to get 1,429 kB of archives.
After this operation, 7,016 kB of additional disk space will be used.
Get:1 http://deb.devuan.org/merged daedalus/main amd64 psmisc amd64 23.6-1 [259 kB]
Get:2 http://deb.devuan.org/merged daedalus/main amd64 libgoa-1.0-common all 3.46.0-1 [178 kB]
Get:3 http://deb.devuan.org/merged daedalus/main amd64 libgoa-1.0-0b amd64 3.46.0-1 [71.4 kB]
Get:4 http://deb.devuan.org/merged daedalus/main amd64 libgdata-common all 0.18.1-2 [110 kB]
Get:5 http://deb.devuan.org/merged daedalus/main amd64 libgdata22 amd64 0.18.1-2 [278 kB]
Get:6 http://deb.devuan.org/merged daedalus/main amd64 libplist3 amd64 2.2.0-6+b2 [33.2 kB]
Get:7 http://deb.devuan.org/merged daedalus/main amd64 libusbmuxd6 amd64 2.0.2-3 [20.6 kB]
Get:8 http://deb.devuan.org/merged daedalus/main amd64 libimobiledevice6 amd64 1.3.0-6+b3 [71.7 kB]
Get:9 http://deb.devuan.org/merged daedalus/main amd64 gvfs-backends amd64 1.50.3-1 [365 kB]
Get:10 http://deb.devuan.org/merged daedalus/main amd64 usbmuxd amd64 1.1.1-2 [41.6 kB]
Fetched 1,429 kB in 1s (1,422 kB/s)
Selecting previously unselected package psmisc.
(Reading database ... 191710 files and directories currently installed.)
Preparing to unpack .../0-psmisc_23.6-1_amd64.deb ...
Unpacking psmisc (23.6-1) ...
Selecting previously unselected package libgoa-1.0-common.
Preparing to unpack .../1-libgoa-1.0-common_3.46.0-1_all.deb ...
Unpacking libgoa-1.0-common (3.46.0-1) ...
Selecting previously unselected package libgoa-1.0-0b:amd64.
Preparing to unpack .../2-libgoa-1.0-0b_3.46.0-1_amd64.deb ...
Unpacking libgoa-1.0-0b:amd64 (3.46.0-1) ...
Selecting previously unselected package libgdata-common.
Preparing to unpack .../3-libgdata-common_0.18.1-2_all.deb ...
Unpacking libgdata-common (0.18.1-2) ...
Selecting previously unselected package libgdata22:amd64.
Preparing to unpack .../4-libgdata22_0.18.1-2_amd64.deb ...
Unpacking libgdata22:amd64 (0.18.1-2) ...
Selecting previously unselected package libplist3:amd64.
Preparing to unpack .../5-libplist3_2.2.0-6+b2_amd64.deb ...
Unpacking libplist3:amd64 (2.2.0-6+b2) ...
Selecting previously unselected package libusbmuxd6:amd64.
Preparing to unpack .../6-libusbmuxd6_2.0.2-3_amd64.deb ...
Unpacking libusbmuxd6:amd64 (2.0.2-3) ...
Selecting previously unselected package libimobiledevice6:amd64.
Preparing to unpack .../7-libimobiledevice6_1.3.0-6+b3_amd64.deb ...
Unpacking libimobiledevice6:amd64 (1.3.0-6+b3) ...
Selecting previously unselected package gvfs-backends.
Preparing to unpack .../8-gvfs-backends_1.50.3-1_amd64.deb ...
Unpacking gvfs-backends (1.50.3-1) ...
Selecting previously unselected package usbmuxd.
Preparing to unpack .../9-usbmuxd_1.1.1-2_amd64.deb ...
Unpacking usbmuxd (1.1.1-2) ...
Setting up libgoa-1.0-common (3.46.0-1) ...
Setting up libplist3:amd64 (2.2.0-6+b2) ...
Setting up psmisc (23.6-1) ...
Setting up libgdata-common (0.18.1-2) ...
Setting up libusbmuxd6:amd64 (2.0.2-3) ...
Setting up libimobiledevice6:amd64 (1.3.0-6+b3) ...
Setting up usbmuxd (1.1.1-2) ...
adduser: Warning: The home dir /var/lib/usbmux you specified can't be accessed: No such file or directory
Adding system user `usbmux' (UID 110) ...
Adding new user `usbmux' (UID 110) with group `plugdev' ...
Not creating home directory `/var/lib/usbmux'.
Processing triggers for libglib2.0-0:amd64 (2.74.6-2) ...
Processing triggers for libc-bin (2.36-9+deb12u3) ...
Processing triggers for man-db (2.11.2-2) ...
Setting up libgoa-1.0-0b:amd64 (3.46.0-1) ...
Setting up libgdata22:amd64 (0.18.1-2) ...
Setting up gvfs-backends (1.50.3-1) ...
freeartist-devuan@home:~/Downloads$ sudo apt install gvfs-fuse
  gvfs-fuse
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 20.5 kB of archives.
After this operation, 64.5 kB of additional disk space will be used.
Get:1 http://deb.devuan.org/merged daedalus/main amd64 gvfs-fuse amd64 1.50.3-1 [20.5 kB]
Fetched 20.5 kB in 0s (97.4 kB/s)
Selecting previously unselected package gvfs-fuse.
(Reading database ... 192119 files and directories currently installed.)
Preparing to unpack .../gvfs-fuse_1.50.3-1_amd64.deb ...
Unpacking gvfs-fuse (1.50.3-1) ...
Setting up gvfs-fuse (1.50.3-1) ...
smile
pyzNi 3.14zDa! smile
#2 2023-10-19 16:27:57
deepforest
Re: Digital Camera not shown in Devices, Thunar
Linux NOT READY YET FOR MASS USAGE AS DESKTOP
smile
#3 2023-10-19 16:48:15
deepforest
After rebooting it shown
but copy progress not shown now and no preview of photos
smile
#4 2023-11-08 01:55:38
LinuxMan
Might want to check if go-mtpfs and jmtpfs are installed
Go-mtpfs is a simple FUSE filesystem for mounting Android devices as
an MTP device.
It will expose all storage areas of a device in the mount, and only
reads file metadata as needed, making it mount quickly. It uses Android
extensions to read/write partial data, so manipulating large files
requires no extra space in /tmp.
After install reboot plug in phone to usb port
