#1 2023-10-19 15:07:35
Pcfan5
LAN without conection - RTL810XE PCI Express Driver r8169
Hello, I am new at the forum, I have searched for this issue before posting. I've also been reading a lot.
I am able to connect to the Internet with a 1.5 mtrs RJ45 cord.
However when I try with a 30 mtrs cords, connection is impossible.  (the same cord works perfectly with other computers a laptop with an intel i5 processor and a netbook with an Atom processor)
The system detects it but I get a generic IP for IPV4 is: 169.254.115.247 (sometimes I mannaged to get the correct one)
I have change everything I could in Connman.
I cannot connect to internet. I wonder if there is an incompatibility regarding the processor and the long cord.
I have checked on the Intel web site but the network device is quite old and there are only drivers for Windows XP
This is my system
System:
  Kernel: 6.1.0-12-amd64 arch: x86_64 bits: 64 Desktop: LXDE v: 0.10.1
    Distro: Devuan GNU/Linux 5 (daedalus)
Machine:
  Type: Desktop Mobo: MICRO-STAR model: G31TM-P21 (MS-7529) v: 1.0
    serial: <superuser required> BIOS: American Megatrends v: 4.7
    date: 07/28/2010
CPU:
  Info: dual core model: Pentium E5300 bits: 64 type: MCP cache: L2: 2 MiB
  Speed (MHz): avg: 1203 min/max: 1203/2603 cores: 1: 1203 2: 1203
Graphics:
  Device-1: Intel 82G33/G31 Express Integrated Graphics driver: i915 v: kernel
  Device-2: Brooktree Bt878 Video Capture driver: bttv v: 0.9.19
  Display: x11 server: X.Org v: 1.21.1.7 driver: X: loaded: intel
    unloaded: fbdev,modesetting,vesa dri: i915 gpu: i915
    resolution: 1280x1024~60Hz
  API: OpenGL v: 2.1 Mesa 22.3.6 renderer: i915 (: G33)
Audio:
  Device-1: Intel NM10/ICH7 Family High Definition Audio driver: snd_hda_intel
  Device-3: Brooktree Bt878 Audio Capture driver: N/A
  API: ALSA v: k6.1.0-12-amd64 status: kernel-api
  Server-1: PulseAudio v: 16.1 status: active
Network:
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
  IF: eth0 state: down mac: <filter>
  Device-2: TP-Link TL-WN722N v2/v3 [Realtek RTL8188EUS] type: USB
    driver: r8188eu
  IF: wlx503eaa3d9c5e state: up mac: <filter>
Drives:
  Local Storage: total: 326.91 GiB used: 145.53 GiB (44.5%)
  ID-1: /dev/sda vendor: Samsung model: HD322HJ size: 298.09 GiB
  ID-2: /dev/sdb type: USB vendor: Kingston model: DataTraveler 3.0
Partition:
  ID-1: / size: 29.76 GiB used: 6.4 GiB (21.5%) fs: ext4 dev: /dev/sda1
  ID-2: /home size: 258.49 GiB used: 122.05 GiB (47.2%) fs: ext4
    dev: /dev/sda2
Swap:
  ID-1: swap-1 type: partition size: 4 GiB used: 4.3 MiB (0.1%) dev: /dev/sda3
Sensors:
  System Temperatures: cpu: 47.0 C mobo: N/A
  Fan Speeds (RPM): N/A
Info:
  Processes: 149 Uptime: 1h 33m Memory: 3.81 GiB used: 1.23 GiB (32.2%)
  Shell: Bash inxi: 3.3.26
I cannot provide information regardin "ipconfig" or "lshw" (terminal says: order not found)
On Connman It detects the MAC Address
Everything is in automatic , however by setting things manually it doesn't work either.
I 've reading about a problem with the kernel. Could this be a driver issue? (cord works fine with other computers, and this computer works fine with a shorter cord hmm )
this is my etc/network/interfaces  file
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
auto lo
iface lo inet loopback
# The primary network interface
auto eth0
iface eth0 inet dhcp
# This is an autoconfigured IPv6 interface
iface eth0 inet6 auto
And here there is a picture from booting screen (after I tried enable/disable LAN controller in BIOS)
https://ibb.co/TM5h96W it takes a lot of time at booting . For installation i used the netinstall iso.
#2 2023-10-19 16:33:13
Re: LAN without conection - RTL810XE PCI Express Driver r8169
Could just be that particular cable - I occasionally use a 30ft cable without problems, (Devuan/XFCE), & have used a 'coupler' to add an extra 10ft cable also without problems.
#3 2023-10-19 16:39:25
Pcfan5
Thank you for you reply . I cankot blame the distro because I have the same problem under several "USB live" distros.
My main concern is it maybe aproblem in the computer since this same long cable works in oyher computers.
#4 2023-10-19 23:30:29
The system is quite old (not that old it NOT should work) and may not supply enough power for a longer cable.
Have you checked your power supply specs?
just a thought...
is the eth chip auto x-over (cable) detect?
#5 2023-10-19 23:59:52
ExposeGlobalistsMadness
You probably mean "command not found", and try ifconfig instead (not ipconfig).
You could try installing lshw:
sudo apt install lshw
Someone else would have to help you with your topic, because that's all I can do.
#6 2023-10-20 02:15:30
Pcfan5
Thank you very much!. Yes, I mean all of that. (My system is in spanish so I made a rough translation).
