Pages: 1
Hi guys,
I have some issues with dropbear and I believe is because ipv6 and therefore I want to disable it.
I didn't find specific documentation on the Debian wiki but this arguable tutorial I found didn't work either:
# Disabling the IPv6
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.default.disable_ipv6 = 1
net.ipv6.conf.lo.disable_ipv6 = 1
updated initramfs and rebooted, but still ipv6.
Any suggestions?
Thanks! 🙏
Hi, I add a ipv6.disable=1 line to grub... the vpn I have only uses ipv4
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# GlennsPref 20230920 ipv6
GRUB_DEFAULT=0
GRUB_TIMEOUT=4
GRUB_DISTRIBUTOR=`lsb_release -i -s`
GRUB_CMDLINE_LINUX_DEFAULT="console=tty12 vga=794 modeset.nouveau=0 nokmsboot ipv6.disable=1"
# discover other os's
GRUB_DISABLE_OS_PROBER=false
GRUB_GFXMODE=1920x1080
GRUB_INIT_TUNE="400 440 1"
# resume=uuid errors... noresume "we don't susspend"
GRUB_CMDLINE_LINUX="noresume idle=nomwait"
GRUB_THEME=/usr/share/desktop-base/grub-themes/desktop-grub-theme/theme.txt
run update-grub as root, and reboot.
all the best
@GlennW that worked, thanks!
Although it says: "ipv6 loaded but administratively disabled" ; it would be cool understand how to prevent ipv6 to be loaded.
Anyway it was enough to let dropbear able to listen in fact I was able to drop the bear into the other pc! 😁
If you don't want ipv6 support, recompile your kernel without ipv6 support, obviously.
Otherwise, disable it as already explained.
I have a devuan-daedalus-6.1.93 running on a Raspberry.
I would like also to disable the ipv6 (system wide)
I've seen many time this:
nano /etc/sysctl.d/disableipv6.conf
#add line:
net.ipv6.conf.all.disable_ipv6=1
But If I don't mistaken this is only for systemd 🤢 ?
In the OP link, is the method 2 nano /etc/modprobe.d/blacklist-ipv6.conf ...
will work on sysv init ?
Thanks.
Linux noob, plz be kind
This is what I use to enable ipv6 in /etc/sysctl.conf . This enables both ipv6 and ipv4
net.ipv6.bindv6only= 0
This would disable ipv6:
net.ipv6.bindv6only=1
Also,
I did a quick web search and this was a top reply. I forgot to save the link, sorry.
How to disable IPv6 with Sysctl?
Open the /etc/sysctl.conf file with the following command:
$ sudo nano /etc/sysctl.conf
Add the following lines to it:
Reload. sysctl.conf. with the following command:
sysctl -p
I think that one, or both, of these methods should work.
try adding
ipv6.disable=1
to the commandline bootcode.
also i seem to recall needing to comment out all the ipv6 stuff in the /etc/hosts file
# commented out all the ipv6 stuff to quiet the /var/log/exim4 report logs
#::1 localhost
#::1 ip6-localhost ip6-loopback
#fe00::0 ip6-localnet
#fe00::0 ip6-mcastprefix
#ff00::0 ip6-mcastprefix
#fe02::1 ip6-allnodes
#fe02::1 ip6-allrouters
#ff02::1 ip6-allnodes
#ff02::2 ip6-allrouters
#ff02::3 ip6-allhosts
#fe80::1%lo0 localhost
you might even check what NetworkManager reports
sudo NetworkManager --print-config
keep us posted on your progress.
I created a init script /init.d/....
with
sysctl -w net.ipv6.conf.default.disable_ipv6=1
sysctl -w net.ipv6.conf.all.disable_ipv6=1
inside.
now just remain to test if IPv6 is really disabled ! (any ideas ?)
with
I don't think that would do much, but I would simply add the two lines to the /etc/sysctl.conf file and then test it out. Be sure to run "sysctl -p" after saving the file.
If you wanted to run the lines of code at boot, you might want to try adding them to the /etc/rc.local file, but I think the /etc/sysctl.conf file would be better.
Pages: 1
