#1 2023-10-14 08:49:16
morning777
[SOLVED] libdvd-pkg install
Hello,
i am a new user to devuan. I tried to find the libdvd-pkg to pl,ay dvd in vlc. But without success in Terminal and Synaptic.
I  have seen it in github but my skills are not enough to build it on my own. Is there a repo i have to activate? What do I miss?
#2 2023-10-14 09:00:35
Re: [SOLVED] libdvd-pkg install
A quick glance at https://pkginfo.devuan.org/libdvd-pkg tells us that the package is in the contrib section.
#3 2023-10-14 09:19:19
morning777
Thank you, it worked!
I installed 'software-properties-common', added contrib-repos: 'apt-add-repository contrib' and installed 'libdvd-pkg'.
