#1 2023-10-11 09:24:04
zeitlos
Problem stopping X server
Hello. To install proprietary nvidia video card drivers, I need to completely stop the X server. However, I can't do this, even by manually killing the process via htop. After the screen goes dark, the X server starts working again.
#2 2023-10-11 23:25:14
Re: Problem stopping X server
Hi, to properly install the proprietary nVidia .run package...?
If you need to block nouveau module...
make a file, /etc/modprobe.d/nvidia-installer-disable-nouveau.conf
# generated by nvidia-installer
blacklist nouveau
options nouveau modeset=0
Make sure you have a build environment, build essentials, linux-headers and libglvnd-dev
Then reboot to safe mode., down arrow at the grub boot loader to
"Advanced options for Dev..."
arrow to (don't use enter) select your kernel and (recovery mode) and press E to edit
move the cursor to the end of the last "linux" line and type
modeset.nouveau=0 vga=794 nokmsboot
and press F10 to boot to "single" mode.
type in the root password when prompted.
install package.
reboot with
shutdown -r now
I hope this helps.
#3 2023-10-13 12:15:19
zeitlos
X The server has stopped. Thanks for the answer, your method works. However, the drivers themselves were unable to get up. The installer writes: "Unable to build the NVIDIA kernel module." Tell me in which direction to look for the problem.
#4 2023-10-14 01:01:05
It's not building for some reason.
apt install libglvnd-dev libglvnd0 pkg-config build-essential gcc12 linux-headers linux-headers-common linux-compiler-gcc-12
check for error messages...
