#1 2023-10-05 22:07:18
jemadux
[SOLVED] ntfs not mounting
i tried to mount a ntfs hdd on my devuan system stable .
I am using xfce4 and stable version of dev1 .
all packages of ntfs are installed
ls -altr /sbin/mount.ntfs
lrwxrwxrwx 1 root root 13 Mar 23  2023 /sbin/mount.ntfs -> mount.ntfs-3g
according to debian forum [1]  the solution  was to install a package and will be fine
but in my case the package is installed
[1]https://forums.debian.net/viewtopic.php?t=154459
Dev1 Stable | openrc | MATE
Greetings from Greece
#2 2023-10-05 22:20:10
Dutch_Master
Re: [SOLVED] ntfs not mounting
Which kernel version do you have installed?
uname -a
It appears NTFS support has not been compiled into your kernel, you may need to change your (specialized) kernel for a generic one instead.
Otherwise it might be an error in your fstab:
cat /etc/fstab | grep ntfs*
Both commands as root.
#3 2023-10-05 23:44:00
jemadux
root@cryptolab:~# uname -a
Linux cryptolab 6.1.0-12-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.52-1 (2023-09-07) x86_64 GNU/Linux
root@cryptolab:~# cat /etc/fstab | grep ntfs*
root@cryptolab:~#
#4 2023-10-06 07:08:39
Is fuse installed?
#5 2023-10-06 07:13:06
jemadux
rolfie wrote:
Is fuse installed?
 apt install fuse
  fuse3 gvfs-fuse ntfs-3g ntfs-3g-dev xdg-desktop-portal xdg-desktop-portal-gtk
  fuse
0 upgraded, 1 newly installed, 6 to remove and 0 not upgraded.
Need to get 61.3 kB of archives.
After this operation, 5,126 kB disk space will be freed.
#6 2023-10-06 07:20:57
jemadux
solved ..
❯ sudo ntfsfix -d /dev/sdb1
Mounting volume... $MFTMirr does not match $MFT (record 3).
FAILED
Attempting to correct errors...
Processing $MFT and $MFTMirr...
Reading $MFT... OK
Reading $MFTMirr... OK
Comparing $MFTMirr to $MFT... FAILED
Correcting differences in $MFTMirr record 3...OK
Processing of $MFT and $MFTMirr completed successfully.
Setting required flags on partition... OK
Going to empty the journal ($LogFile)... OK
Checking the alternate boot sector... OK
NTFS volume version is 3.1.
NTFS partition /dev/sdb1 was processed successfully.
source https://bbs.archlinux.org/viewtopic.php?id=271650
#7 2023-10-06 08:19:49
Well, strange. When posting the fuse hint I forgot that the old fuse has been replaced by fuse3.
Its working here on my workstation with fuse3 and ntfs-3g, no kernel modules.
