#1 2023-10-04 21:07:41
Robert
[SOLVED] X freeze after switching vt
During my migration from Chimaera to Daedalus I have lost the xserver settings.
Now I run X on the first virtual terminal, everything works well.
But after switching to another virtual terminal I can not go back: I see a black screen and all I can do is kill X from another terminal.
I am not familiar with the X so please help me with this problem.
#2 2023-10-04 22:47:19
Re: [SOLVED] X freeze after switching vt
You could try updating xserver-xorg-core and xserver-common from daedalus-proposed-updates. That might resolve the VT switching issue.
Thus, add to sources.list:
deb http://deb.devuan.org/merged daedalus-proposed-updates main
deb-src http://deb.devuan.org/merged daedalus-proposed-updates main
Then run (as root)
# apt-get update
# apt-get install --no-install-recommends -t daedalus-proposed-updates xserver-xorg-core ]xserver-common
#3 2023-10-05 14:10:59
Robert
Thank you very much! This solved the problem!
