#1 2023-09-29 20:06:45
Danielsan
From Debian to Devuan (Odroid-XU4)
From the Odroid Forum I read about a dude that installed a Debian iso made for this board and then he followed the standard procedure to convert Debian into Devuan, this sound pretty cool but...
Do you believe that is really feasible?
I am using Armbian right now with some very annoying issues, and guess what?
All of them are systemd service failing for unknown reasons.
I could actually testing it with a SD card, it would be very cool using Devuan instead of Armbian... ๐Ÿค”
#2 2023-09-30 00:08:09
Danielsan
Re: From Debian to Devuan (Odroid-XU4)
It actually worked out
Now for running from the eMMC it is required further jumps on the hoops, but it looks feasible, for testing I've just installed the full DE on a SD card but it is working fine.
Even the GPU acceleration is working:
# glxinfo | grep rendering && glxinfo | grep vendor
direct rendering: Yes
server glx vendor string: SGI
client glx vendor string: Mesa Project and SGI
OpenGL vendor string: Mesa/X.org\
Now I would just replace sysvinit with runit!
Any wiki to follow plz?
#3 2023-09-30 00:20:48
I can't help you for runit, but I'm very interested in learning how to de-brick after an attempt to move the OS onto the eMMC.
#4 2023-09-30 00:46:54
Danielsan
For what I read you need to flash the eMMC, and then change some files regarding uboot: https://forum.odroid.com/viewtopic.php?p=371017#p371017
Anyway I am not going that far until a bookworm image won't be available.
This was a test to check the feasibility, and it was a success!  ๐ŸŽŠ ๐ŸŽŠ ๐ŸŽŠ
#5 2023-10-03 14:19:08
Danielsan
Odroid Bookworm is on its own way...
https://forum.odroid.com/viewtopic.php?p=375557#p375557
Once released I will try to install it on the eMMC module and then to convert it in Devuan Deadalus plus runit! ๐Ÿ˜Ž
