#1 2023-09-22 11:31:17
sisqonrw
use Bluetooth
i have boot with an devuan live usb stick (daedalus).
how can i use the bluetooth? how can i start the bluetooth manager, etc.?
#2 2023-09-22 14:39:08
sisqonrw
Re: use Bluetooth
can someone help me please. i need bluetooth to listen music.
#3 2023-09-22 16:04:39
Re: use Bluetooth
I seldom use bluetooth, but this describes setting it up - https://www.howtogeek.com/829360/how-to … -on-linux/
#4 2023-09-22 16:44:29
sisqonrw
Re: use Bluetooth
Hi i have install this
sudo apt install bluez*
sudo apt install blueman
bluetooth manager find my bluetooth headset but tells
"Connecton failed: br-connection-profile-unavailable
whats wrong here?
#5 2023-09-22 19:58:09
Re: use Bluetooth
2nd search hit was: https://askubuntu.com/questions/1479606 … untu-23-04
pipewire is a good option for bluetooth, and the answer is for debian 12. Probably worth a try.
#6 2023-09-22 21:12:35
sisqonrw
Re: use Bluetooth
i have try it but to not work. to complicated. normaly it should work directly.
#7 2023-09-23 08:54:39
Re: use Bluetooth
1st removed pulseaudio-module-bluetooth. Then installed libspa-0.2-bluetooth. Restartred system. My wireless bluetooth headphone is working fine now. Hope it helps.
Sounds simple enough.... wink
#8 2023-09-23 11:31:08
sisqonrw
Re: use Bluetooth
i have remove pulseaudio-module-bluetooth
i have installed  libspa-0.2-bluetooth
restart it.
but sadly it do not work.
#9 2023-09-23 12:52:56
ExposeGlobalistsMadness
Re: use Bluetooth
There were a variety of different working solutions reported in Archlinux by different users for you to try, if you can just remember or lookup (or ask) for the equivalence of any service handling between systemd and your Devuan init.  Would pulseaudio-bluetooth in Arch correspond to pulseaudio-module-bluetooth in Devuan?
There were also solutions reportedly working on previous pages of that thread.  If something works for you, please let us know, thanks!
#10 2023-09-23 22:50:22
sisqonrw
Re: use Bluetooth
what should i test know? can you tell me the commands. than i can try it. that is no problem. i can give than a feedback.
thanks
