Pages: 1
Hello everybody!
They say a pic is worth a thousand words
Changing the font globally via xfce settings makes no difference.
Any ideas are appreciated!
Thank you!
p.s. After some gooogling tried 'Exec=QT_SCALE_FACTOR=1.25' but it didn't help either
$ Exec=QT_SCALE_FACTOR=1.25 /opt/viber/Viber %u
qt.webenginecontext:
GL Type: desktop
Surface Type: OpenGL
Surface Profile: NoProfile
Surface Version: 2.1
QSG RHI Backend: OpenGL
Using Supported QSG Backend: yes
Using Software Dynamic GL: no
Using Multithreaded OpenGL: yes
Init Parameters:
* allow-loopback-in-peer-connection
* application-name ViberPC
* autoplay-policy no-user-gesture-required
* browser-subprocess-path /opt/viber/libexec/QtWebEngineProcess
* disable-features ConsolidatedMovementXY,InstalledApp,BackgroundFetch,WebOTP,WebPayments,WebUSB,PictureInPicture,AudioServiceOutOfProcess
* disable-setuid-sandbox
* disable-speech-api
* enable-features NetworkServiceInProcess,TracingServiceInProcess,NetworkServiceInProcess
* enable-threaded-compositing
* enable-use-zoom-for-dsf false
* enable-usermedia-screen-capture
* in-process-gpu
* use-gl desktop
QHighDpiScaling::setFactor: Should only be called when no windows exist.
... ideas are appreciated!
I cannot find that package in any of the Devuan repositories.
I cannot find it in the Debian repositories either.
At this time, Devuan is Debian albeit without systemd so if a package is not in the Debian repositories you won't find it in the Devuan repositories.
Where did you get it from?
How did you install it?
Maybe flatpak issue...
Pages: 1
