#1 2023-09-16 23:18:28
chomwitt
Default dhcp client floods my syslog
Devuan release: Daedalus
Installed on: PC
dpkg -l  | grep dhcp
ii  isc-dhcp-client                        4.4.3-P1-2                      amd64        DHCP client for automatically obtaining an IP address
ii  isc-dhcp-common                        4.4.3-P1-2                      amd64        common manpages relevant to all of the isc-dhcp packages
Trying to tail my /var/log/syslog i see that is constantly flooded with messages:
2023-09-16T21:06:58.845413+03:00 enous-devuan dhclient[18775]: Failed to get interface index: No such device
2023-09-16T21:06:58.845422+03:00 enous-devuan dhclient[18775]:
2023-09-16T21:06:58.845426+03:00 enous-devuan dhclient[18775]: If you think you have received this message due to a bug rather
2023-09-16T21:06:58.845430+03:00 enous-devuan dhclient[18775]: than a configuration issue please read the section on submitting
2023-09-16T21:06:58.845434+03:00 enous-devuan dhclient[18775]: bugs on either our web page at www.isc.org or in the README file
2023-09-16T21:06:58.845438+03:00 enous-devuan dhclient[18775]: before submitting a bug.  These pages explain the proper
2023-09-16T21:06:58.845441+03:00 enous-devuan dhclient[18775]: process and the information we find helpful for debugging.
2023-09-16T21:06:58.845445+03:00 enous-devuan dhclient[18775]:
2023-09-16T21:06:58.845449+03:00 enous-devuan dhclient[18775]: exiting.
2023-09-16T21:06:59.885543+03:00 enous-devuan dhclient[18786]: Internet Systems Consortium DHCP Client 4.4.3-P1
2023-09-16T21:06:59.885550+03:00 enous-devuan dhclient[18786]: Copyright 2004-2022 Internet Systems Consortium.
2023-09-16T21:06:59.885553+03:00 enous-devuan dhclient[18786]: All rights reserved.
2023-09-16T21:06:59.885556+03:00 enous-devuan dhclient[18786]: For info, please visit https://www.isc.org/software/dhcp/
Those lines keep repating.
For now i will try to instal   udhcpc.
Interestingly udhcpc wont show any conflicts with isc-dhcp-client   . Shouldnt it?
Also i noticed that
$ update-alternatives --get-selections doenst have a dhcp entry. But couldnt have one since there are more than one dchp clients and deamons?
@ devuanwiki/Chomwitt
#2 2023-09-17 02:28:54
Re: Default dhcp client floods my syslog
Apparently your machine runs multiple dhclient processes competing about the interfaces.
Which networking do you use? Do you use ifupdown (which primarily is configured with /etc/network/interfaces) or something else, or several?
#3 2023-09-17 14:58:20
Geoff 42
I have spotted two copies of dhclient running after upgrading to daedalus.
I am using runit and, clearly, one copy was being started by runit but the other was less easy to track down. I came to the conclusion that one copy was started by the networking software, presumably related to /etc/network/interfaces .
The version started from runit has now been removed
update-service --remove /etc/sv/dhclient
and the VM (under Xen) where I am testing it, still boots ok with just the one copy of dhclient.
Interestingly, the runit copy was earlier complaining even more about not being able to find eth1. I then spotted that the new runit setup for dhclient had a config file in conf/interfaces which contained
INTERFACES=eth1
Changing this to eth0 soon solved that. But this is no longer in use!
Geoff
#4 2023-09-17 15:44:15
chomwitt
Its a clean netinstal installation. I did nothing out of the ordinary. Except now that i installed udchpc.
#5 2023-09-17 22:26:21
Could please show your /etc/network/interfaces file?
#6 2023-09-18 14:35:30
Lorenzo
This is a bug in dhclient script shipped with runit-services package
https://bugs.debian.org/cgi-bin/bugrepo … ug=1033542
is fixed in testing and unstable, but stable will have to wait untill the next point release hmm
To fix it, both methods suggested by Geoff will work
INTERFACES=eth1
basically disable the service or replace 'eth1' in /etc/sv/dhclient/conf/interfaces
with an interface that exists in your system (look at the output of ifconfig)
The commit that fix it is here
https://salsa.debian.org/Lorenzo.ru.g-g … e19d826ded
Said that, I see that this service is annoying a lot of people for several reason, I wonder if (for the future) it will be better to ship the dhclient service as disabled-by-default: opinions are welcome
Regards,
Lorenzo
#7 2023-09-18 14:59:13
Geoff 42
Thank you for looking into this, Lorenzo.
My Chimaera installation is happy without runit starting a copy of dhclient, and having removed it from Daedalus, that also seems happy. So I would think that having it disabled-by-default is probably the correct thing to do.
I am not an expert in networking so I a not sure when we would need to run a copy of dhclient from the init system.
Geoff
