#1 2023-09-14 08:05:44
Charon795
[SOLVED] Removing the WhiteSur theme
Hi all! Recently I was interested in the WhiteSur-Light topic from Xfce-Look.org
I downloaded the archive of this theme, went to settings-appearance and added this theme.
Having used this theme, I decided to download another one, but from the official repository, and I managed to do it. But now I don't understand how to delete the WhiteSur theme.
I wrote the command sudo apt remove WhiteSur-light, but it gave me an error, then I decided to look at the correct name of this theme. I wrote the command apt search theme | less but didn’t find this topic there.
This theme is also not in the Usr/share/themes/ location.
Perhaps the theme is in the .themes folder
I checked using the command sudo find / -iname "*WhiteSur-Light*"
gives the location .themes/WhiteSur-Light
I wrote the command sudo rm -rf WhiteSur-light, but still nothing. The theme does not disappear in the settings - appearance
#2 2023-09-14 08:58:08
soren
Re: [SOLVED] Removing the WhiteSur theme
Try the command like so
rm -rf ~/.themes/WhiteSur-Light
EDIT: dont use sudo, no need.
#3 2023-09-14 10:45:31
Charon795
Nope, the topic never went away sad
I just pasted the command and no messages appeared in the terminal after that, and the topic was never deleted
#4 2023-09-14 10:50:13
soren
Can you post the output of below command and use code tags when replying please.
ls -al ~/.themes
#5 2023-09-14 10:54:00
Charon795
ls -al ~/.themes
ldrwxr-xr-x 2 root root 4096 сен 13 21:34 .
drwx------ 6 root root 4096 сен 13 21:34 ..
#6 2023-09-14 11:06:41
soren
Looks like you are logging is a root?
#7 2023-09-14 11:12:47
Charon795
When I started the terminal I entered the su command and entered the root password.
After that I always tried to remove whitesur, but nothing worked..
After writing your command, nothing changed either, but after re-entering the terminal and entering your command again, the WhiteSur theme was deleted
It turns out that the problem was that I wrote the "su" command, huh ..
#8 2023-09-14 11:20:52
soren
No need to use SU (super user) when working in your home directory.
Here is a good article on the use of the super user account, which should be used wisely.
https://linuxize.com/post/su-command-in-linux/
#9 2023-09-14 11:24:32
soren
Charon795 wrote:
ps: can you now please also help me remove the WhiteSur icons ^^"?
Same process, this time maybe the icons are in /home/<your user>/.icons so let us know the output of below command first before we remove any files.
ls -al ~/.icons
#10 2023-09-14 11:28:12
Charon795
ls -al ~/.icons
I have already written the following commands and removed the necessary icons
Thanks for your help
xanther@devuan:~$ cd ~/.icons
xanther@devuan:~/.icons$ ls -a
.  ..  Tela  Tela-dark  Tela-light  WhiteSur  WhiteSur-dark
xanther@devuan:~/.icons$ rm -rf WhiteSur
xanther@devuan:~/.icons$ rm -rf WhiteSur-dark
#11 2023-09-14 11:29:36
soren
Your welcome.
