#1 2023-09-10 22:40:55
chomwitt
Sway with seatd
I was happy to read in Daedalus release notes:
### Wayland GUI without elogind
Users can now enjoy a wayland desktop without elogind by installing
libpam-ck-connector, sway and seatd.
The main reason is that i like to have options and secondly (but not least important) i like to have a system that feels less opaque regarding the functionality offered by each package.
So i started a desktopless fresh installation into my PC and i gradually installed various packages in order to setup a decent , ligthweight desktop based on sway but without elogind and using seatd.
For reason that i dont currently undrestand sway wont start unless  libpam-ck-connector
is installed. (that package is mentioned also in  'Devuan without elogind' by Iggy64 but again with no much explanation.
So sway starts by command line and  i am happy but various application try to pull elogind and also to remove libpam-ck-connector.
Example:
$ sudo apt-get install calibre
  libpam-ck-connector libsystemd0
  blt calibre calibre-bin eject elogind ...
So i try:
$ sudo apt-get install calibre elogind-
  libpam-ck-connector
  blt calibre calibre-bin dummy-logind
What can i do in that case ?
@ devuanwiki/Chomwitt
#2 2023-09-11 00:38:07
hunter0one
Re: Sway with seatd
libpam-ck-connector is for Consolekit2 to communicate with PAM. Consolekit2 is a more Unix respecting alternative to elogind and seatd is used alongside it to cover Wayland sessions.
#3 2023-09-11 16:01:48
chomwitt
Re: Sway with seatd
but why do i need PAM to access my pc that i am the only user ?
#4 2023-09-12 12:49:32
Re: Sway with seatd
Because you are a system administrator.
More info here:
https://en.wikipedia.org/wiki/Linux_PAM
#5 2023-09-14 10:57:48
chomwitt
Re: Sway with seatd
thanks stopAI .
I see the broad picture now . How PAM is a common authentication functionality library-service .
I ll try to dig little deeper and see how seatd- consolekit2-pam and greetd work together. Because in first glance apt depents fields dont offer any insigths and reading the project's sites seems that consolekit2 functonality overalps seatd.
ps: how to stop AI ? I think by creating p2p AI and fediverse AI ?
#6 2023-09-14 11:37:41
Re: Sway with seatd
chomwitt wrote:
thanks stopAI .
The only way to deal with the threat from AI is shut It down!
#7 2023-09-23 14:58:26
chomwitt
Re: Sway with seatd
System : Daedalus , sway+seatd+libpam-ck-connector
I find a way to install Calibre without pulling elogind  .
(due to past command: sudo dpkg --add-architecture i386 we see also various i386 packages)
       libasound2-plugins:i386 libpam-ck-connector libpulse0:i386
       libsdl2-2.0-0:i386 libsystemd0 libsystemd0:i386
After we lowering apt priority to -1 for elogind in /etc/apt/preferences :
       libpam-ck-connector libsystemd0 libsystemd0:i386
       blt calibre calibre-bin eject elogind:i386
After we lowering apt priority to -1 for elogind:i386 in /etc/apt/preferences :
       libpam-ck-connector
       blt calibre calibre-bin dummy-logind ..
I didnt found how to keep 'libpam-ck-connector' from being removed in /etc/apt/preferences
but that command worked:
$ sudo apt-mark hold libpam-ck-connector
 // now libpam-ck-connector was not listed for removal but
 // neither dummy-logind for installation. But calibre was installed and seems to work ok.
Checking afterward in cases i missed something:
$ sudo apt-cache policy elogind
elogind:
  Installed: (none)
  Candidate: (none)
$ sudo apt-cache policy elogind:i386
elogind:i386:
  Installed: (none)
  Candidate: (none)
And here is my /etc/apt/preferences
Althougth as i noted  the libpam-ck-connector didnt work.
Package: elogind
Pin: release a=stable
Pin-Priority: -1
Package: elogind:i386
Pin-Priority: -1
Package: libpam-ck-connector
Pin-Priority: 1001
Please for anyone usiing  Daedalus with sway , seatd] and libpam-ck-connector it would be great to hear how you installed packages that try to remove libpam-ck-connector or pull elogind.
#8 2023-10-16 18:37:01
czeekaj
Re: Sway with seatd
I am not running into many issues if elogind is still installed. dependency wise you don't really need to run it but more uncomplicated if it's present.
