#1 2023-09-08 17:30:41
nixer
How to Hibernate and Suspend
The following information was taken mostly from the following link:
https://askubuntu.com/questions/848698/ … nux-distro
Situation:  Computers have this thing called power saving using Hibernation and Suspend.  I had never used it because, well, I never configured it correctly - but I really did not try very hard.  For a lot of years, I always left the computer running all day and would sometimes shut it down at night.  My local utility raised the electricity rates recently, so I thought I would try a little harder.
Result:  I have Hibernation and Suspend working flawless and upon waking up the system by either pressing the power button or typing a key on the keyboard or wiggling the mouse the system works perfectly.  Even if I save the system state with virtual machines running, they too will work perfectly.
How to configure for Hibernate/Suspend, taken from other devuan sources - mainly from dev1galaxy.org:
My system started as chimaera and was upgraded to daedalus.
- Create a swap partition as least as large as your current amount or RAM.
- Configure your system to use this partition as your swap area.
- at terminal run "blkid" to get the uuid info for this partition
- Add this swap partition to fstab
UUID=12345-your-uuid none    swap    sw    0    0
- Add entry to /etc/initramfs-tools/conf.d/resume
RESUME=UUID=12345-your-uuid
- Update initramfs with:
update-initramfs -u
-    reboot
This should get the Hibernation and Suspend working from the xfce menu.  In my case, I had a problem getting the system to wake up by pressing a keyboard key or moving the mouse.  Pressing the system power button worked fine.  I then found the link above and ran two commands to get some system information, and then made an entry to the /etc/rc.local file.
Command #1, as root:
grep . /sys/bus/usb/devices/*/product
This will produce output that looks like this, as it will list your usb devices.  My usb keyboard and mouse were the bottom two:
/sys/bus/usb/devices/1-3/product:ASM107x
/sys/bus/usb/devices/1-4/product:HD Pro Webcam C920
/sys/bus/usb/devices/1-5/product:USB Receiver
/sys/bus/usb/devices/1-6/product:USB Receiver
Command #2, as root:
grep . /sys/bus/usb/devices/*/power/wakeup
This will list the devices and whether they will be allowed to wake the system:
Note: all of mine were disabled, which is why they were not waking up the system.
/sys/bus/usb/devices/1-3/power/wakeup:disabled
/sys/bus/usb/devices/1-5/power/wakeup:disabled
/sys/bus/usb/devices/1-6/power/wakeup:disabled
In my case, I wanted my usb keyboard and usb mouse to wake the system, so I added this to my /etc/rc.local file:
echo enabled > /sys/bus/usb/devices/1-5/power/wakeup
echo enabled > /sys/bus/usb/devices/1-6/power/wakeup
Note:
In daedalus I had to add "sleep 30" to the  /etc/rc.local  to get it to work:
So the related contents of the rc.local file is:
sleep 30
Now, when I step away from the system and I don't know when I will return, I simply Menu > Logout > Suspend.  When I shut it down at night, I Menu > Logout > Hibernate.  These could be shortened with a script added to the desktop.
This works flawlessly now and has for over a year.  Hope this helps someone.
