#1 2023-09-05 07:17:14
hejik
Qemu shared folder
Is there a way to run a qemu-kvm VM with a shared folder via terminal?
#2 2023-09-05 12:18:34
Re: Qemu shared folder
#3 2023-09-05 12:41:29
I've done it with sshfs, either mounting a directory from the host on the VM or the other way, mounting a directory in the VM on the host.  The former can be done without any network options in the qemu command. You do need to have sshfs installed.
sshfs user@host-ip:/home/user/some-subdirectory  some-mountpoint-in-the-VM
fusermount -u some-mountpoint-in-the-VM   # to un-mount the share
I've done it with nfs, too. That's a little more involved. You can even set it up with autofs so the share mounts automatically when you access the mountpoint.
#4 2023-09-05 21:19:23
pcalvert
ralph.ronnquist wrote:
I've used this. It works. I like the fact that a normal, non-root user can write to the shared directory from the guest system. I seem to recall that on VirtualBox I always had to be root in order to do that.
Another one is called Luxxle.
