#1 2023-08-31 20:26:57
James1138
Question - adding earlier Devuan repos as option restore to Python2
Hello all from Indiana.
I see as of Devuan 4 / Debian 11, Python2 has been dropped from its repositories since no longer supported. However, I have some older apps like OpenTeacher that rely on Python2 and wonder if adding eariler repos such as ASCII & Beowulf allow installing Python2?
Google search turns up things like "Python-PIP" - sounds confusing and iffy (to me anyway) as a solution for adding Python2 back.
James
#2 2023-08-31 22:08:55
mrnhmath
Re: Question - adding earlier Devuan repos as option restore to Python2
You can compile it from source or manually download and install the python2.7 and libpython2.7-stdlib deb packages from the oldstable repository.
