#1 2023-08-29 07:17:15
HelenSmith
Application Menu Bar disappeared and the solution
Joking:
“Only a fool learns from his own mistakes. The wise learns from the mistakes of others.”
I am the fool.
VLC, VirtualBox,
Some menu bars disappeared from the applciations which are always at the top of the applications, and I was confused for a long time.
At last I found out the cause and the solution.
The cause: Remove the Panel by accidently
The solution: On the Desktop(right click)->Add Panel->Applciation Menu Bar.
OK.
I hope this mesage may be helpful for some people some day.
devuan_daedalus_5.0.0_amd64_desktop, upgraded from devuan_4.0,
session: KDE_Plasma(x11)
