try build xscreensaver with such parameters
./configure --prefix=/usr --with-elogind --with-pam --with-gl --with-glx --with-pixbuf --with-xft
its needed for fully worked all demos at my videocard
but i have many warnings after configuration, how to resolve this?
Warning: The "pkg-config" program was not found. Without that,
detection of the various GTK libraries won't work.
Warning: The GTK libraries do not seem to be available; the
`xscreensaver-settings' program requires them.
Warning: The Xt library was not found. It is required.
Warning: Use of GDK-Pixbuf was requested, but it was not found.
Some of the demos will not use images as much as they could.
You should consider installing GDK-Pixbuf and re-running
configure.
Warning: The JPEG library was not found.
This means that it won't be possible for the image-manipulating
display modes to load files from disk; and it also means that
the `webcollage' program will be much slower.
Warning: The PNG library was not found.
More specifically, we found the headers but not the
libraries. Possibly a 'devel' package is needed.
Many things aren't going to work right.
Warning: The XInput2 library was not found. It is required.
Warning: The XFreeType library was not found. It is required.
Warning: The systemd library was not found.
This means that xscreensaver-systemd won't be built.
Without that, xscreensaver will not be able to auto-lock
before the system is suspended (e.g., closing laptop lid)
and might activate while video playback is in progress.
Warning: The OpenGL 3D library is required, but it was not found.
Those demos which use 3D will not be built or installed.
That is most of them.
Warning: Use of PAM was requested, but it was not found.
You need the dev-files. As quoted here:
There are many compilation dependencies. The configure script will tell
you what is missing. At the least, you will need development versions of
these libraries. Append "-dev" or "-devel" to most of these:perl pkg-config gettext intltool libx11 libxext libxi libxt libxft
libxinerama libxrandr libxxf86vm libgl libglu libgle libgtk-3-0
libgdk-pixbuf2.0 libjpeg libxml2 libpam libsystemd elogind
from here:
If you don't need the latest upstream version, then it would probably be easier to use the debian source and debian tools to rebuild the package the way you want it. Take a look at this: https://raphaelhertzog.com/2010/12/15/h … -packages/
Thanks.
But. Example. If i build pkg from Testing and install it at Stable is it safe its not broke my system?
May be easy way to do that by backporting repo?
libgdk-pixbuf2.0 libjpeg libxml2 libpam libsystemd elogindfrom here:
Thanks.
So i can just do
apt install perl pkg-config gettext intltool libx11 libxext libxi libxt libxft
There's no need to backport a newer version. Pull the source from daedalus to alter the version in daedalus.
root@home:/home/freeartist-devuan# apt install perl pkg-config gettext intltool libx11 libxext libxi libxt libxft
libgdk-pixbuf2.0 libjpeg libxml2 libpam elogind
E: Unable to locate package libx11
E: Unable to locate package libxext
E: Unable to locate package libxi
E: Unable to locate package libxt
E: Unable to locate package libxft
bash: libxinerama: command not found
bash: libgdk-pixbuf2.0: command not found
root@home:/home/freeartist-devuan# apt install perl pkg-config gettext intltool libx11-6 libxext-dev libxi-dev libxt-dev libxft-dev
perl is already the newest version (5.36.0-7).
gettext is already the newest version (0.21-12).
gettext set to manually installed.
intltool is already the newest version (0.51.0-6).
libx11-6 is already the newest version (2:1.8.4-2+deb12u1).
libx11-6 set to manually installed.
libbrotli-dev libexpat1-dev libfontconfig-dev libfontconfig1-dev libfreetype-dev libice-dev libpkgconf3 libpng-dev libsm-dev libxfixes-dev libxrender-dev pkgconf pkgconf-bin uuid-dev
zlib1g-dev
Suggested packages:
freetype2-doc libice-doc libsm-doc libxext-doc libxt-doc
libbrotli-dev libexpat1-dev libfontconfig-dev libfontconfig1-dev libfreetype-dev libice-dev libpkgconf3 libpng-dev libsm-dev libxext-dev libxfixes-dev libxft-dev libxi-dev
libxrender-dev libxt-dev pkg-config pkgconf pkgconf-bin uuid-dev zlib1g-dev
0 upgraded, 20 newly installed, 0 to remove and 0 not upgraded.
Need to get 4,111 kB of archives.
After this operation, 11.0 MB of additional disk space will be used.
all installed except this
same warnings
The PNG library is being used instead.
configure.
install deps
94 apt install perl pkg-config gettext intltool libx11-6 libxext-dev libxi-dev libxt-dev libxft-dev
95 libxinerama libxrandr libxxf86vm libgl libglu libgle libgtk-3-0
96 libgdk-pixbuf2.0 libjpeg libxml2 libpam elogind
97 apt install libgtk-3-0
98 sudo apt install --reinstall libgl-dev
99 sudo apt-get install libglu1-mesa-dev freeglut3-dev mesa-common-dev
100 sudo apt-get install libgtk2.0-dev
101 sudo apt-get install libgdk-pixbuf2.0-dev
102 apt remove xscreensaver
103 sudo apt-get install libgtk3.0-dev
104 sudo apt-get install libgtk-3-dev
105 sudo apt-get install libxml-2.0
106 apt-get install libxml2-dev
107 history
configure
XScreenSaver will be installed in these directories:
User programs: /usr/bin/
Screen savers: /usr/libexec/xscreensaver/
Configuration: /usr/share/xscreensaver/config/
Extra Fonts: /usr/share/fonts/xscreensaver/
App Defaults: /etc/X11/app-defaults/
freeartist-devuan@home:~/Downloads/xscreensaver-6.06$
make
Merging translations into xscreensaver.desktop.
Found cached translation database
gcc -std=gnu89 -pedantic -Wall -Wnested-externs -Wstrict-prototypes -Wmissing-prototypes -Wdeclaration-after-statement -Wno-overlength-strings -Wno-language-extension-token -Wno-variadic-macros -L/usr/lib -o xscreensaver-gfx xscreensaver-gfx.o screens.o windows.o subprocs.o exec.o prefsw.o dpms.o fade.o exts.o atomswm.o prefs.o blurb.o atoms.o clientmsg.o xinput.o ../utils/xmu.o ../utils/yarandom.o ../utils/resources.o ../utils/visual.o ../utils/usleep.o ../utils/font-retry.o ../utils/logo.o ../utils/minixpm.o ../utils/screenshot.o ../utils/xft.o ../utils/utf8wc.o ../utils/xshm.o ../utils/aligned_malloc.o -lSM -lICE -lXft -lXinerama -lXrandr -lXrender -lXi -lXt -lX11 -lXext -lXi
Merging translations into xscreensaver.service.
gcc -std=gnu89 -pedantic -Wall -Wnested-externs -Wstrict-prototypes -Wmissing-prototypes -Wdeclaration-after-statement -Wno-overlength-strings -Wno-language-extension-token -Wno-variadic-macros -L/usr/lib -o xscreensaver-auth xscreensaver-auth.o dialog.o passwd.o setuid.o passwd-pwent.o blurb.o screens.o xinput.o prefs.o atoms.o atomswm.o ../utils/xft.o ../utils/xftwrap.o ../utils/utf8wc.o ../utils/font-retry.o ../utils/yarandom.o ../utils/usleep.o ../utils/resources.o ../utils/logo.o ../utils/minixpm.o -lSM -lICE -lXft -lXi -lXinerama -lXrandr -lXrender -lXi -lXt -lX11 -lXext -lXi -lcrypt
demo-Gtk.c: In function ‘save_window_position’:
demo-Gtk.c:4827:33: warning: ‘%s’ directive argument is null [-Wformat-overflow=]
4827 | fprintf (stderr, "%s: geom: %s => %s\n", blurb(), old, str);
At top level:
cc1: note: unrecognized command-line option ‘-Wno-language-extension-token’ may have been intended to silence earlier diagnostics
gcc -std=gnu89 -pedantic -Wall -Wnested-externs -Wstrict-prototypes -Wmissing-prototypes -Wdeclaration-after-statement -Wno-overlength-strings -Wno-language-extension-token -Wno-variadic-macros -L/usr/lib -o xscreensaver-settings-Gtk demo-Gtk.o demo-Gtk-conf.o demo-Gtk-resources.o blurb.o exec.o prefs.o prefsw.o dpms.o remote.o screens.o clientmsg.o atoms.o ../utils/xmu.o ../utils/resources.o ../utils/visual.o ../utils/screenshot.o ../utils/usleep.o -lSM -lICE -lXinerama -lXrandr -lXrender -lgtk-3 -lgdk-3 -lz -lpangocairo-1.0 -lpango-1.0 -lharfbuzz -latk-1.0 -lcairo-gobject -lcairo -lgio-2.0 -Wl,--export-dynamic -lgmodule-2.0 -pthread -lglib-2.0 -lxml2 -lgdk_pixbuf-2.0 -lgobject-2.0 -lglib-2.0 -lXt -lX11 -lXext -lXi
cp -p xscreensaver-settings-Gtk xscreensaver-settings
make[1]: Leaving directory '/home/freeartist-devuan/Downloads/xscreensaver-6.06/driver'
make[1]: Entering directory '/home/freeartist-devuan/Downloads/xscreensaver-6.06/po'
make[1]: Nothing to be done for 'default'.
make[1]: Leaving directory '/home/freeartist-devuan/Downloads/xscreensaver-6.06/po'
make install
freeartist-devuan@home:~/Downloads/xscreensaver-6.06$ make install
make[1]: Entering directory '/home/freeartist-devuan/Downloads/xscreensaver-6.06/utils'
make[1]: Nothing to be done for 'install'.
make[1]: Leaving directory '/home/freeartist-devuan/Downloads/xscreensaver-6.06/utils'
make[1]: Entering directory '/home/freeartist-devuan/Downloads/xscreensaver-6.06/jwxyz'
make[1]: Leaving directory '/home/freeartist-devuan/Downloads/xscreensaver-6.06/jwxyz'
make[1]: Entering directory '/home/freeartist-devuan/Downloads/xscreensaver-6.06/hacks/images'
make[1]: Leaving directory '/home/freeartist-devuan/Downloads/xscreensaver-6.06/hacks/images'
make[1]: Entering directory '/home/freeartist-devuan/Downloads/xscreensaver-6.06/hacks'
/usr/bin/install: cannot change permissions of ‘/usr/libexec/xscreensaver’: No such file or directory
/usr/bin/install -c attraction /usr/libexec/xscreensaver/attraction
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/attraction': No such file or directory
/usr/bin/install -c blitspin /usr/libexec/xscreensaver/blitspin
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/blitspin': No such file or directory
/usr/bin/install -c bouboule /usr/libexec/xscreensaver/bouboule
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/bouboule': No such file or directory
/usr/bin/install -c braid /usr/libexec/xscreensaver/braid
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/braid': No such file or directory
/usr/bin/install -c decayscreen /usr/libexec/xscreensaver/decayscreen
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/decayscreen': No such file or directory
/usr/bin/install -c deco /usr/libexec/xscreensaver/deco
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/deco': No such file or directory
/usr/bin/install -c drift /usr/libexec/xscreensaver/drift
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/drift': No such file or directory
/usr/bin/install -c flame /usr/libexec/xscreensaver/flame
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/flame': No such file or directory
/usr/bin/install -c galaxy /usr/libexec/xscreensaver/galaxy
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/galaxy': No such file or directory
/usr/bin/install -c grav /usr/libexec/xscreensaver/grav
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/grav': No such file or directory
/usr/bin/install -c greynetic /usr/libexec/xscreensaver/greynetic
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/greynetic': No such file or directory
/usr/bin/install -c halo /usr/libexec/xscreensaver/halo
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/halo': No such file or directory
/usr/bin/install -c helix /usr/libexec/xscreensaver/helix
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/helix': No such file or directory
/usr/bin/install -c hopalong /usr/libexec/xscreensaver/hopalong
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/hopalong': No such file or directory
/usr/bin/install -c ifs /usr/libexec/xscreensaver/ifs
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/ifs': No such file or directory
/usr/bin/install -c imsmap /usr/libexec/xscreensaver/imsmap
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/imsmap': No such file or directory
/usr/bin/install -c julia /usr/libexec/xscreensaver/julia
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/julia': No such file or directory
/usr/bin/install -c kaleidescope /usr/libexec/xscreensaver/kaleidescope
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/kaleidescope': No such file or directory
/usr/bin/install -c maze /usr/libexec/xscreensaver/maze
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/maze': No such file or directory
/usr/bin/install -c moire /usr/libexec/xscreensaver/moire
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/moire': No such file or directory
/usr/bin/install -c noseguy /usr/libexec/xscreensaver/noseguy
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/noseguy': No such file or directory
/usr/bin/install -c pedal /usr/libexec/xscreensaver/pedal
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/pedal': No such file or directory
/usr/bin/install -c penrose /usr/libexec/xscreensaver/penrose
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/penrose': No such file or directory
/usr/bin/install -c pyro /usr/libexec/xscreensaver/pyro
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/pyro': No such file or directory
/usr/bin/install -c qix /usr/libexec/xscreensaver/qix
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/qix': No such file or directory
/usr/bin/install -c rocks /usr/libexec/xscreensaver/rocks
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/rocks': No such file or directory
/usr/bin/install -c rorschach /usr/libexec/xscreensaver/rorschach
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/rorschach': No such file or directory
/usr/bin/install -c sierpinski /usr/libexec/xscreensaver/sierpinski
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/sierpinski': No such file or directory
/usr/bin/install -c slidescreen /usr/libexec/xscreensaver/slidescreen
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/slidescreen': No such file or directory
/usr/bin/install -c slip /usr/libexec/xscreensaver/slip
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/slip': No such file or directory
/usr/bin/install -c strange /usr/libexec/xscreensaver/strange
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/strange': No such file or directory
/usr/bin/install -c swirl /usr/libexec/xscreensaver/swirl
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/swirl': No such file or directory
/usr/bin/install -c goop /usr/libexec/xscreensaver/goop
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/goop': No such file or directory
/usr/bin/install -c starfish /usr/libexec/xscreensaver/starfish
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/starfish': No such file or directory
/usr/bin/install -c munch /usr/libexec/xscreensaver/munch
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/munch': No such file or directory
/usr/bin/install -c fadeplot /usr/libexec/xscreensaver/fadeplot
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/fadeplot': No such file or directory
/usr/bin/install -c rdbomb /usr/libexec/xscreensaver/rdbomb
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/rdbomb': No such file or directory
/usr/bin/install -c coral /usr/libexec/xscreensaver/coral
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/coral': No such file or directory
/usr/bin/install -c mountain /usr/libexec/xscreensaver/mountain
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/mountain': No such file or directory
/usr/bin/install -c triangle /usr/libexec/xscreensaver/triangle
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/triangle': No such file or directory
/usr/bin/install -c xjack /usr/libexec/xscreensaver/xjack
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/xjack': No such file or directory
/usr/bin/install -c xlyap /usr/libexec/xscreensaver/xlyap
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/xlyap': No such file or directory
/usr/bin/install -c cynosure /usr/libexec/xscreensaver/cynosure
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/cynosure': No such file or directory
/usr/bin/install -c moire2 /usr/libexec/xscreensaver/moire2
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/moire2': No such file or directory
/usr/bin/install -c flow /usr/libexec/xscreensaver/flow
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/flow': No such file or directory
/usr/bin/install -c epicycle /usr/libexec/xscreensaver/epicycle
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/epicycle': No such file or directory
/usr/bin/install -c interference /usr/libexec/xscreensaver/interference
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/interference': No such file or directory
/usr/bin/install -c truchet /usr/libexec/xscreensaver/truchet
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/truchet': No such file or directory
/usr/bin/install -c bsod /usr/libexec/xscreensaver/bsod
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/bsod': No such file or directory
/usr/bin/install -c crystal /usr/libexec/xscreensaver/crystal
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/crystal': No such file or directory
/usr/bin/install -c discrete /usr/libexec/xscreensaver/discrete
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/discrete': No such file or directory
/usr/bin/install -c distort /usr/libexec/xscreensaver/distort
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/distort': No such file or directory
/usr/bin/install -c kumppa /usr/libexec/xscreensaver/kumppa
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/kumppa': No such file or directory
/usr/bin/install -c demon /usr/libexec/xscreensaver/demon
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/demon': No such file or directory
/usr/bin/install -c loop /usr/libexec/xscreensaver/loop
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/loop': No such file or directory
/usr/bin/install -c penetrate /usr/libexec/xscreensaver/penetrate
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/penetrate': No such file or directory
/usr/bin/install -c deluxe /usr/libexec/xscreensaver/deluxe
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/deluxe': No such file or directory
/usr/bin/install -c compass /usr/libexec/xscreensaver/compass
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/compass': No such file or directory
/usr/bin/install -c squiral /usr/libexec/xscreensaver/squiral
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/squiral': No such file or directory
/usr/bin/install -c xflame /usr/libexec/xscreensaver/xflame
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/xflame': No such file or directory
/usr/bin/install -c wander /usr/libexec/xscreensaver/wander
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/wander': No such file or directory
/usr/bin/install -c spotlight /usr/libexec/xscreensaver/spotlight
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/spotlight': No such file or directory
/usr/bin/install -c phosphor /usr/libexec/xscreensaver/phosphor
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/phosphor': No such file or directory
/usr/bin/install -c xmatrix /usr/libexec/xscreensaver/xmatrix
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/xmatrix': No such file or directory
/usr/bin/install -c petri /usr/libexec/xscreensaver/petri
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/petri': No such file or directory
/usr/bin/install -c shadebobs /usr/libexec/xscreensaver/shadebobs
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/shadebobs': No such file or directory
/usr/bin/install -c ccurve /usr/libexec/xscreensaver/ccurve
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/ccurve': No such file or directory
/usr/bin/install -c blaster /usr/libexec/xscreensaver/blaster
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/blaster': No such file or directory
/usr/bin/install -c bumps /usr/libexec/xscreensaver/bumps
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/bumps': No such file or directory
/usr/bin/install -c ripples /usr/libexec/xscreensaver/ripples
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/ripples': No such file or directory
/usr/bin/install -c xspirograph /usr/libexec/xscreensaver/xspirograph
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/xspirograph': No such file or directory
/usr/bin/install -c nerverot /usr/libexec/xscreensaver/nerverot
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/nerverot': No such file or directory
/usr/bin/install -c xrayswarm /usr/libexec/xscreensaver/xrayswarm
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/xrayswarm': No such file or directory
/usr/bin/install -c zoom /usr/libexec/xscreensaver/zoom
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/zoom': No such file or directory
/usr/bin/install -c whirlwindwarp /usr/libexec/xscreensaver/whirlwindwarp
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/whirlwindwarp': No such file or directory
/usr/bin/install -c rotzoomer /usr/libexec/xscreensaver/rotzoomer
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/rotzoomer': No such file or directory
/usr/bin/install -c speedmine /usr/libexec/xscreensaver/speedmine
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/speedmine': No such file or directory
/usr/bin/install -c vermiculate /usr/libexec/xscreensaver/vermiculate
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/vermiculate': No such file or directory
/usr/bin/install -c twang /usr/libexec/xscreensaver/twang
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/twang': No such file or directory
/usr/bin/install -c apollonian /usr/libexec/xscreensaver/apollonian
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/apollonian': No such file or directory
/usr/bin/install -c euler2d /usr/libexec/xscreensaver/euler2d
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/euler2d': No such file or directory
/usr/bin/install -c polyominoes /usr/libexec/xscreensaver/polyominoes
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/polyominoes': No such file or directory
/usr/bin/install -c fluidballs /usr/libexec/xscreensaver/fluidballs
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/fluidballs': No such file or directory
/usr/bin/install -c anemone /usr/libexec/xscreensaver/anemone
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/anemone': No such file or directory
/usr/bin/install -c halftone /usr/libexec/xscreensaver/halftone
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/halftone': No such file or directory
/usr/bin/install -c metaballs /usr/libexec/xscreensaver/metaballs
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/metaballs': No such file or directory
/usr/bin/install -c eruption /usr/libexec/xscreensaver/eruption
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/eruption': No such file or directory
/usr/bin/install -c popsquares /usr/libexec/xscreensaver/popsquares
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/popsquares': No such file or directory
/usr/bin/install -c barcode /usr/libexec/xscreensaver/barcode
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/barcode': No such file or directory
/usr/bin/install -c piecewise /usr/libexec/xscreensaver/piecewise
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/piecewise': No such file or directory
/usr/bin/install -c cloudlife /usr/libexec/xscreensaver/cloudlife
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/cloudlife': No such file or directory
/usr/bin/install -c fontglide /usr/libexec/xscreensaver/fontglide
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/fontglide': No such file or directory
/usr/bin/install -c apple2 /usr/libexec/xscreensaver/apple2
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/apple2': No such file or directory
/usr/bin/install -c xanalogtv /usr/libexec/xscreensaver/xanalogtv
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/xanalogtv': No such file or directory
/usr/bin/install -c pong /usr/libexec/xscreensaver/pong
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/pong': No such file or directory
/usr/bin/install -c filmleader /usr/libexec/xscreensaver/filmleader
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/filmleader': No such file or directory
/usr/bin/install -c wormhole /usr/libexec/xscreensaver/wormhole
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/wormhole': No such file or directory
/usr/bin/install -c pacman /usr/libexec/xscreensaver/pacman
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/pacman': No such file or directory
/usr/bin/install -c fuzzyflakes /usr/libexec/xscreensaver/fuzzyflakes
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/fuzzyflakes': No such file or directory
/usr/bin/install -c anemotaxis /usr/libexec/xscreensaver/anemotaxis
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/anemotaxis': No such file or directory
/usr/bin/install -c memscroller /usr/libexec/xscreensaver/memscroller
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/memscroller': No such file or directory
/usr/bin/install -c substrate /usr/libexec/xscreensaver/substrate
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/substrate': No such file or directory
/usr/bin/install -c intermomentary /usr/libexec/xscreensaver/intermomentary
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/intermomentary': No such file or directory
/usr/bin/install -c fireworkx /usr/libexec/xscreensaver/fireworkx
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/fireworkx': No such file or directory
/usr/bin/install -c fiberlamp /usr/libexec/xscreensaver/fiberlamp
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/fiberlamp': No such file or directory
/usr/bin/install -c boxfit /usr/libexec/xscreensaver/boxfit
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/boxfit': No such file or directory
/usr/bin/install -c interaggregate /usr/libexec/xscreensaver/interaggregate
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/interaggregate': No such file or directory
/usr/bin/install -c celtic /usr/libexec/xscreensaver/celtic
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/celtic': No such file or directory
/usr/bin/install -c cwaves /usr/libexec/xscreensaver/cwaves
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/cwaves': No such file or directory
/usr/bin/install -c m6502 /usr/libexec/xscreensaver/m6502
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/m6502': No such file or directory
/usr/bin/install -c abstractile /usr/libexec/xscreensaver/abstractile
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/abstractile': No such file or directory
/usr/bin/install -c lcdscrub /usr/libexec/xscreensaver/lcdscrub
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/lcdscrub': No such file or directory
/usr/bin/install -c hexadrop /usr/libexec/xscreensaver/hexadrop
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/hexadrop': No such file or directory
/usr/bin/install -c tessellimage /usr/libexec/xscreensaver/tessellimage
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/tessellimage': No such file or directory
/usr/bin/install -c binaryring /usr/libexec/xscreensaver/binaryring
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/binaryring': No such file or directory
/usr/bin/install -c glitchpeg /usr/libexec/xscreensaver/glitchpeg
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/glitchpeg': No such file or directory
/usr/bin/install -c vfeedback /usr/libexec/xscreensaver/vfeedback
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/vfeedback': No such file or directory
/usr/bin/install -c scooter /usr/libexec/xscreensaver/scooter
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/scooter': No such file or directory
/usr/bin/install -c marbling /usr/libexec/xscreensaver/marbling
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/marbling': No such file or directory
/usr/bin/install -c binaryhorizon /usr/libexec/xscreensaver/binaryhorizon
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/binaryhorizon': No such file or directory
/usr/bin/install -c xscreensaver-getimage /usr/libexec/xscreensaver/xscreensaver-getimage
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/xscreensaver-getimage': No such file or directory
/usr/bin/install -c webcollage-helper /usr/libexec/xscreensaver/webcollage-helper
/usr/bin/install: cannot create regular file '/usr/libexec/xscreensaver/webcollage-helper': No such file or directory
make[1]: *** [Makefile:286: install-program] Error 1
make[1]: Leaving directory '/home/freeartist-devuan/Downloads/xscreensaver-6.06/hacks'
make: *** [Makefile:34: install] Error 5
Solved!
sudo make install
OK, good that you got it installed. Keep in mind that apt doesn't know about it and the package won't get upgraded automatically.
I can explain a couple of the errors you were getting.
"Command not found" occurs when the package name is the first item on the line. That can happen when you copy/paste a list of package names - you paste more than one wrapped line.
The packages that can't be found have incomplete names. There is no libx11 but there are a bunch of libx11 packages. Same goes for libxext and those others. For example:
$ apt-cache search libxext
libxext-dev - X11 miscellaneous extensions library (development headers)
libxext-doc - X11 miscellaneous extensions library (documentation)
libxext6 - X11 miscellaneous extension library
@fsmithred
Thanks a lot for usefull explain!
