#1 2023-08-25 12:28:53
Tritonio
Lazarus package broken?
I am trying to install lazarus and apt gives me:
 lazarus-2.2 : Depends: lcl-2.2 (>= 2.2.6+dfsg2-2) but it is not installable
               Recommends: fpc
Synaptic also shows red boxes if I try to tick it.
Have I broken my repositories? I'm on Daedalus, recently upgraded from Chimaera.
Here's my sources.list:
deb http://deb.devuan.org/merged daedalus main non-free contrib
deb-src http://deb.devuan.org/merged daedalus main non-free contrib
deb http://pkgmaster.devuan.org/merged daedalus-security main contrib non-free
deb-src http://pkgmaster.devuan.org/merged daedalus-security main contrib non-free
deb http://deb.devuan.org/merged daedalus-updates main contrib non-free
deb-src http://deb.devuan.org/merged daedalus-updates main contrib non-free
deb http://deb.devuan.org/merged daedalus-backports main contrib non-free
deb-src http://deb.devuan.org/merged daedalus-backports main contrib non-free
#2 2023-08-25 12:44:11
Re: Lazarus package broken?
Have you done
apt-get update
.. or whatever the corresponding button presses are on the gui tool?
Have you done
apt-get upgrade
Have you done
apt-get dist-upgrade
Thoe are the three steps to follow after having changed sources.list.
#3 2023-08-25 13:24:47
Tritonio
Hello Ralph. I've done all three during the upgrade to Daedalus and I've done the first two multiple times after it to fetch updates to my installed packages. I tried again right now and I did not see any packages that I have not upgraded (and it did fetch the repos again).
Digging a bit deeper it looks like it fails because
lcl-2.2 is not installable because
lcl-gtk2-2.2 is not installable because
fp-units-gtk2 is an unmet dependency because
libatk1.0-dev depends on libatk1.0-0 (= 2.46.0-5) but 2.48.3-1~bpo12+1 is to be installed and, additionally, libatk1.0-dev depends on gir1.2-atk-1.0 (= 2.46.0-5) but 2.48.3-1~bpo12+1 is to be installed.
So I guess they need an exact version but I have a newer one already installed from stable-backports because of gimp-gap.
But gimp-gap needs any libatk1.0-dev version above or equal to 1.12.4, so why isn't apt simply downgrading my libatk1.0-0 version to fix the dependencies?
As for the gir1.2-atk-1.0 dependency it's because lutris depends on gir1.2-gtk-3.0 which in turn depends on gir1.2-atk-1.0 (>= 2.35.1) which once more means that apt should be able to downgrade from the backported 2.48.3 to 2.46.0 and lutris will be happy too.
I guess apt isn't that smart and I need to manually fix the versions of these two packages? (gir1.2-atk-1.0 and libatk1.0-0) Is there anything I need to remember if I fix their versions? For example, how do I know that I'm not missing out on security updates on them?
#4 2023-08-25 13:54:37
You can check all available versions (wrt your sources.list) of a package P with
apt-cache policy P
That tells if there are any associated security updates.
You can also review package P (wrt to a larger sources.list) at https://pkginfo.devuan.org/P.
#5 2023-08-25 16:31:03
Should you have non-free-firmware in your sources.list? I don't think that would cause this problem but might cause problems with hardware support later.
#6 2023-08-25 17:46:34
apt will not downgrade a package versions, unless you pin it.
#7 2023-08-25 22:30:38
a few things I sometimes use, not mentioned here...
# apt auto-remove -y
# apt --fix-broken install   #with no packages (or specify a solution).
# dpkg -i --auto-deconfigure
# dpkg -i -G # -G do not down Grade
of course, with dpkg you need the package's location.
I hope this helps.
