#1 2023-08-19 08:56:43
brgs
[SOLVED] Where do the packages go... when support runs out?
Hi all,
I got this old PC sitting in the corner, still running Devuan ASCII.  Now I lost
some packages due to a hd-crash, and surprisingly  support did run out
some time ago.
Is there some kind of archive of old packages?
greettings, brgs
I use: ksh, qed, c, awk, links, dietlibc and mwm
#2 2023-08-19 09:19:06
Re: [SOLVED] Where do the packages go... when support runs out?
yes, ascii has been moved. You should update your sources list to these
deb http://archive.devuan.org/merged ascii main
deb http://archive.devuan.org/merged ascii-backports main
deb http://archive.devuan.org/merged ascii-proposed-updates main
deb http://archive.devuan.org/merged ascii-security main
(add contrib and non-free as desired)
#3 2023-08-19 10:08:48
brgs
Thanks alot!
