#1 2023-08-16 16:00:01
amaro
upgrade warnings pipewire
Hello everybody!
upgrading 'mpv' got some 'pipewire' messages
Unpacking pipewire-bin (0.3.77-1~bpo12+1) over (0.3.19-4) ...
dpkg: warning: unable to delete old directory '/etc/pipewire/media-session.d': Directory not empty
dpkg: warning: unable to delete old directory '/etc/pipewire': Directory not empty
Setting up pipewire-bin (0.3.77-1~bpo12+1) ...
Removing obsolete conffile /etc/pipewire/pipewire.conf ...
Removing obsolete conffile /etc/pipewire/media-session.d/alsa-monitor.conf ...
Removing obsolete conffile /etc/pipewire/media-session.d/media-session.conf ...
prior to the upgrade listening to online radio worked flawlessly
mpv some-online-radio-url
Resuming playback. This behavior can be disabled with --no-resume-playback.
 (+) Audio --aid=1 (mp3 2ch 44100Hz)
AO: [pulse] 44100Hz stereo 2ch float
A: 00:00:00 / 00:00:05 (18%) Cache: 3.9s/139KB
after the upgrade
[ao/pipewire] Could not connect to context '(null)': Host is down
A: 00:00:00 / 00:00:05 (18%) Cache: 3.9s/140KB
Is it necessary to delete the old 'pipewire' directory? If so, where is the new 'pipewire" directory?
/etc/pipewire
Is the 'pipewire' line during 'mpv' usage an issue?
Thank you in advance!
