#1 2023-08-15 18:52:56
DaveT
[SOLVED] HOWTO make pysolfc work in Daedalus
Pysolfc in the Debian and Devuan repos is so old it needs the file /usr/lib/python3.9/formatter.py
The version of Python in Debian 12 and Devuan Daedalus is 3.11 and formatter.py no longer exists.
Obviously I did a dist-upgrade from Chimaera so I had Pysolfc installed already, it just refused to run!
Linux Mint provided the answer.
Download Python 3.9.17 - or whatever the latest version of 3.9 is when you need to do this.
Use xarchiver or similar to extract ONLY Python-3.9.17/Lib/formatter.py
I created /home/my-username/temptemp and worked from there.
Now copy formatter.py into /usr/lib/python3.11.
And it works!
The real problem is that the debian maintainer of Pysolfc can't be bothered to update the 4 year old version of Pysolfc to the latest v2.20.1 released in April 2023.
Note that Pysolfc is in debian 11, removed from the latest debian 12, but is back in debian sid!
But still the same old v2.6 that still won't work.
A brave soul raised a bug in debian but nothing has been done about it.
#2 2023-08-15 20:40:40
Re: [SOLVED] HOWTO make pysolfc work in Daedalus
I don't use it (yet) but thanks for the hack.
regards, Glenn
#3 2023-08-16 08:16:55
Thanks; noted. smile
