#1 2023-08-05 08:57:55
Taz
[SOLVED] Is it possible to install czkawka?
The installation of czkawka hangs with a missing dependency libgtk-4-dev which is apparently not installable.
Any suggestions on how to get around this very welcome I have over a dozen old drives to back up and dedup.
Taz
#2 2023-08-05 10:50:22
Re: [SOLVED] Is it possible to install czkawka?
Taz
Hello. This program have Appimage. Tray using appimage. Here link
https://github.com/qarmin/czkawka/releases/
#3 2023-08-05 11:04:05
Taz wrote:
... czkawka hangs with a missing dependency libgtk-4-dev which is apparently not installable.
What version of Devuan are you attempting to install it in?
That package does not seem to be in the Debian repositories.
And as you surely know, not in the Debian repositories => not in the Devuan repositories.
That said, libgtk-4-dev is only available ceres:
https://pkginfo.devuan.org/cgi-bin/pack … .10.4+ds-2
and daedalus:
https://pkginfo.devuan.org/cgi-bin/pack … 4.8.3+ds-2
#4 2023-08-05 15:46:59
Taz
Thank you for the suggestions.
This package has an appimage but the appimage depends on libgtk-4-dev which is not installable because I am on chimaera so it looks like install daedalus if I really want this program or find another dedup program that will install.
#5 2023-08-05 18:12:22
The point on appimage is to have no dependencies.
Try the big one - the small one is a broken, it has the mentioned dependency.
#6 2023-08-08 20:22:17
Taz
Thanks didn't realise there were two images.
I fixed it by upgrading to daedalus
