#1 2023-07-24 07:09:54
devur
[SOLVED] Shared partition is not showing up in thunar
shared partition is not visible in thunar
i have tried to create a shared drive between two linux distro on the same hdd but after mounting sda5 it doesn't show up i Thunar 4.16.8
@devuan:~# lsblk -f
NAME   FSTYPE FSVER LABEL UUID                                 FSAVAIL FSUSE% MOUNTPOINT
sda
├─sda1 vfat   FAT32       ED35-DE71                             499,8M     2% /boot/efi
├─sda2 ext4   1.0         f717867f-4d52-44ba-8440-03b17ae2293a  182,9G     8% /
├─sda3 swap   1           e473a17d-7436-49c8-ad08-790b10319f96                [SWAP]
├─sda4 ext4   1.0         2c1816a2-0ad5-43a5-86e1-6addbdaa2e8e
└─sda5 ext4   1.0         1d79ec5c-6257-4086-adeb-a5dae3b83ca2   12,9G     0% /delt
sr0
@devuan:~# ls -al /dev/sda5
brw-rw---- 1 hans disk 8, 5 Jul 24 07:57 /dev/sda5
#2 2023-07-24 14:14:07
Re: [SOLVED] Shared partition is not showing up in thunar
Is /dev/sda5 mounted?
#3 2023-07-24 17:59:44
cardinal
Mounted partitions other than / will have no icon/name in Devices unless you add
comment=x-gvfs-show
to mount options in /etc/fstab.
Hardware: Generic AMD64 Desktop
Description:    Devuan GNU/Linux 6 (excalibur/ceres)
Release:    6
#4 2023-07-25 06:21:45
devur
yes sda5 i mounted under /delt
I have added this line to fstab but there is no sda5 drive in the thunar
# nyt delt drev /dev/sda5
UUID=1d79ec5c-6257-4086-adeb-a5dae3b83ca2       /delt   ext4    defaults        0       0       comment=x-gvfs-show
i did mount -a but white no output
@devuan:~# mount -a
@devuan:~# ls -la /dev/sda5
brw-rw---- 1 root disk 8, 5 Jul 25 07:44 /dev/sda5
#5 2023-07-25 08:39:48
devur
hi
i found a new problem white my sda5 drive
i ignored the new add line in fstab whit a # and that made the sda5 hdd show op i thunar, but i haw to login as root so i changes owner but white now effect
brw-rw---- 1 root disk 8, 5 Jul 25 10:21 /dev/sda5
@devuan:~# chown hans /dev/sda5
brw-rw---- 1 hans disk 8, 5 Jul 25 10:21 /dev/sda5
i haw a scream shut that whose login root required
and after reboot
brw-rw---- 1 root disk 8, 5 Jul 25 10:25 /dev/sda5
#6 2023-07-25 12:52:08
I think Thunar belongs to XFCE. I am no XFCE user, mine is Cinnamon and Mate. What I can tell is:
When /dev/sda5 is mounted to /delt, you should be able to find the mount point in the file system structure. Open Thunar, then open the File System. There you should see /delt. Try to open. May fail due to access rights.
To your post #5: all devices belong to /root, there is NO way to change rights to other than root.
What you need to do is when  /dev/sda5 is mounted to /delt:
Open a root console, in there:
# lsblk
# df -h
# cd /delt
# mkdir hans
# chown hans.hans hans
#7 2023-07-26 08:31:36
devur
hi and yes i assume that you suggest i remount sda5 to /delt/hans ?
lsblk
@devuan:~# lsblk
NAME   MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
sda      8:0    0 465,8G  0 disk
├─sda1   8:1    0   512M  0 part /boot/efi
├─sda2   8:2    0 214,3G  0 part /
├─sda3   8:3    0     8G  0 part [SWAP]
├─sda4   8:4    0   229G  0 part
└─sda5   8:5    0    14G  0 part
sr0     11:0    1  1024M  0 rom
df -h
@devuan:~# df -h
Filesystem      Size  Used Avail Use% Mounted on
udev            3,8G     0  3,8G   0% /dev
tmpfs           777M  1,3M  776M   1% /run
/dev/sda2       210G   17G  183G   9% /
tmpfs           5,0M  4,0K  5,0M   1% /run/lock
tmpfs           3,2G     0  3,2G   0% /dev/shm
/dev/sda1       511M   12M  500M   3% /boot/efi
tmpfs           777M   12K  777M   1% /run/user/1000
chown
@devuan:/delt# chown hans.hans hans
mount
@devuan:~# mount /dev/sda5 /delt/hans
lsblk
@devuan:~# lsblk
└─sda5   8:5    0    14G  0 part /delt/hans
OK that dos it now i can se my shared folder in /delt/hans     smile and smile produces smile
