#1 2023-07-11 14:09:50
sgage
[SOLVED] Strange Firefox bug in Daedalus
I am experiencing a strange bug in Firefox in Daedalus. In an effort to get the maximum amount of vertical space for my browser window, I usually disable the display of the Firefox titlebar - there's a checkbox in the 'customize toolbar' screen for this purpose. It does not work in Daedalus. I've tried reinstalling FF, deleting my config to start clean. It does not work in a clean install of Daedalus, nor in system upgraded from Chimaera (where it works as expected). It works in Debian Bookworm.
What could possibly be causing this behavior? I'd like to fix it. It doesn't sound like show-stopper (and it isn't), but I begrudge every vertical pixel that's wasted on this silly wide-screen monitor. Any ideas?
TIA...
#2 2023-07-11 15:21:38
Re: [SOLVED] Strange Firefox bug in Daedalus
apt remove gtk3-nocsd libgtk3-nocsd
Tested on desktop-live iso.
You have to remove libgtk3-nocsd. Just getting rid of the main package doesn't fix it.
#3 2023-07-11 15:38:29
sgage
That did it! Thanks so much!
