#1 2023-06-28 17:55:57
mclien
VeraCrypt installation method?
as I need a usb stick, which should be encrypted and be usable on Linux and Windows my search came up with VeraCrypt.
I read some here in the forum, too. But I'm missing what the method for installation should be.
I didn't find it with apt, so according to the VeraCrypt website it leaves me with the tar.gz installation or deb-packages.
Has anyone experience to share on that?
#2 2023-06-28 18:18:39
tomec
Re: VeraCrypt installation method?
All the .deb packages give dependency errors, the only functional one was the generic tar archive: I unpacked it and successfully ran the x64 gtk binary inside.
#3 2023-06-28 19:17:11
mclien
Thanks, will do it that way then
#4 2023-06-28 19:38:27
mclien
Hm, I got something wrong, I guess.
Tried the ..-gtk3-gui and was asked for admin rights. Does this work only with sudo rights? So do I need to have the user in sudoers?
EDIT:
Still missing something.
I change in the dir
./veracryp-..-setup-gtk3-gui
I get a (gtk) popup, which asks my pw,
I get an ok for uncompressing the installer
While the 2nd terminal just gives a "Press retun to exit"
That's all. No idea where I'm lost here..
#5 2023-06-28 21:22:36
tylerdurden
Hi mclien,
Have you tried zulucrypt-gui? It's only an apt-get away.
It may also be worth learning how to do this manually with LUKS+LVM. This can come in quite handy if you don't have a GUI available and applies to encrypted volumes on regular hard drives as well.
Here's an example for a USB stick, assuming the drive is on /dev/sdb:
# set up encryption
sudo cryptsetup -s 512 -y luksFormat /dev/sdb1
# open encrypted volume
sudo cryptsetup luksOpen /dev/sdb1 data
# create physical volume
pvcreate /dev/mapper/data
# create volume group
vgcreate usb-vg /dev/mapper/data
# create logical volume
lvcreate -l 100%FREE -n mydata usb-vg
# make nodes
sudo vgscan --mknodes
# activate logical volume
sudo vgchange -ay
# create FS (e.g. XFS)
sudo mkfs.xfs -L USBSTICK /dev/usb-vg/mydata
# mount
sudo mount /dev/usb-vg/mydata /mnt
# umount
sudo umount /mnt
# deactivate logical volume
sudo lvchange -an usb-vg/mydata
# close LUKS partition
sudo cryptsetup close data
# eject drive
sudo eject /dev/sdb
Hope this helps.
#6 2023-06-28 23:54:37
tomec
Yes, it will do a system-wide installation so it definitely needs the admin password.
#7 2023-06-29 19:57:01
As a long time user: TC and Veracrypt before 1.24 were .tar.bz2 files. Extracted to /tmp, always used the gui versions. From 1.24 onward Veracrypt offers .deb packages.
Installation was like:
# ./veracrypt-1.19-setup-gui-x64
From 1.24 onward use
# dpkg -i *.deb
Missing dependencies were easily fixe with
# apt --fix-broken install
Using TC/VC as user requires sudo and an entry in the sudoers:
user  ALL=(root) NOPASSWD: /usr/bin/veracrypt
Add the correct username for "user".
