#1 2023-06-28 14:47:24
t-90
Is gdebi broken?
I installed gdebi on Devuan Chimaera (converted from Debian Bullseye) using
apt install gdebi-core
Whenever I try to install a .deb package, I get the following error:
# gdebi
  File "/usr/bin/gdebi", line 38, in <module>
    from GDebi.GDebiCli import GDebiCli
  File "/usr/share/gdebi/GDebi/GDebiCli.py", line 24, in <module>
    import apt
ModuleNotFoundError: No module named 'apt'
#2 2023-07-01 08:22:08
cafinux
Re: Is gdebi broken?
I had trouble with gdebi some time ago, they said they were fixing it. But I found I could cd into the directory where the deb file was and just use apt to achieve the same result.
# apt ./<the full deb file name>
