#1 2023-06-28 00:53:54
tylerdurden
UsrMerge in Daedalus
Hi folks,
Now that Bookworm defaults to UsrMerge, I was wondering what this means for Daedalus?
I recently tested the latest Daedalus preview (20230601) and it still asked whether I wanted /bin and /sbin to be simlinked to /usr/bin and /usr/sbin or not. Am I correct in assuming that Daedalus will not default to UsrMerge and let the user decide?
If so, I'd be very happy indeed.
My other question would be this: do you think it will be technically feasible to maintain the traditional Linux file system layout in the future given that UsrMerge appears to have become almost a standard of sorts across various distros that want to go the "immutable" route?
Full disclaimer: while not dogmatically opposed to improvements to the Linux file system layout, I'll be frank: I'm not a fan of this particular approach to the matter and remain skeptical of the rationales behind it.
Ever since I started using Devuan, I've consistently chosen to keep the traditional file system layout because it makes sense to me to keep the distinction between /usr and what I tend to regard as the "base system".
Thanks.
#2 2023-07-08 13:14:43
tylerdurden
Re: UsrMerge in Daedalus
Just wanted to add an update:
I tested Devuan Daedalus RC2 just recently and it defaults to the traditional layout as in previous releases, i.e. UsrMerge is still optional.
So if you want to preserve the non-merged, traditional layout (i.e. /bin and /sbin are not symlinked to /usr/bin and /usr/sbin), that is still possible.
Very glad to see this and thank you Devuan developers!
Extra update:
This applies to RC4 as well.
